Old 02-12-2013, 08:02 AM   #1
service upgrade
I am upgrading my service and have to relocate my panel becuase it is in a corner of wall at the basement steps. i read that you need 3 feet of clearence on each side and front is that true?
Im in new jersey with pse&g do i have to notify them?
Is a permit needed?
Can i use old panel as junction box to extend circuits?
Can the panel stay at bottom of steps?
How far from meter before i need a disconnect?
Any help appreciated
dum1 is offline   Reply With Quote
Old 02-12-2013, 08:17 AM   #2
service upgrade
Yes you need to notify PSE&G and yes you need to get permits. They will not do a service upgrade without a permit and they won't upgrade any connections until it has passed final inspection. I would use a licensed pro for this and not try to DIY a panel upgrade based on your questions.
clydesdale is offline   Reply With Quote
Old 02-12-2013, 08:58 AM   #3
MarginallyQualified
service upgrade
*based on your questions*
Even without having all those questions...
there is a LOT of rather specific work all to be done (and coordinated with the power company and the inspector) that very few situations will allow one person to get done by themselves in the course of the one day that most situations NEED it to be completed in.
Old 02-12-2013, 09:43 AM   #4
Lic Electrical Inspector
electures's Avatar
service upgrade
Is a permit needed? Absolutely! Follow this link for downloadable forms.
Can i use old panel as junction box to extend circuits? Yes. More information can be found here in post #6.
Can the panel stay at bottom of steps? New panel or old panel? The new panel falls under the ReHab Subcode found here and can remain in the existing location.
How far from meter before i need a disconnect? The NEC states "as near as possible to the point of entrance". There is no specific distance in the NEC. Follow this link for PSE&G requirements.
Answers in red.
Check out this thread I started for DIY electrical work in New Jersey.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 02-12-2013, 10:43 AM   #5
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
service upgrade
I would see if they can have an engineer come out to meet with you to talk about placement and height of new service or requirements for underground if that is how it has to be done.
Then I would find a meter main that they approve of get install service cable meter main ground rods water bonding per NEC or local amendments and install a sub panel with main inside wherever works best and meets codes you can put it just about anywhere because of the OCPD in the meter main.
Once that passes I would find out if you can feed the old panel with your new panel or use it as a junction box worst case you may have to remove the old panel and use junction boxes.
When I do service upgrades I like the meter mains then I can go anywhere I want inside to feed a new or existing panel as long as it meets the inspectors approval. Here they allow me to get the new service inspected and connected with the meter main and all I have to do is call them back to inspect how I do the work inside. And customers are without power for a very short time. Once they cut the old service and connect the new service all they have to do is wait for me to run a feed from the meter main to a new or existing panel.
I did one they disconnected the old service and while they were connecting the new one I already had conduit and wire going from the meter main to the old panel and just had to disconnect the old service wire in the panel and connect it to the meter main feed a break the neutral ground bond flip a breaker in the meter main and they had power in about 20 min. Inspector comes back and gives the final approval.
Customers love it that they are not waiting around for an inspector and POCO reconnect sometimes not till late at night.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 11:51 AM   #6
eastcoastsparky's Avatar
service upgrade
Originally Posted by electures
Answers in red.
So he can leave it in that corner of the basement of the steps?
eastcoastsparky is offline   Reply With Quote
Old 02-12-2013, 10:52 PM   #7
electures's Avatar
service upgrade
Under the New Jersey REHab Subcode, without knowing the specifics I believe he can. Pics would help.
Are you a contractor?
Sizing motors
Old 02-13-2013, 07:12 AM   #8
service upgrade
Newly licensed
The Following User Says Thank You to eastcoastsparky For This Useful Post:
electures (02-13-2013)
Old 02-13-2013, 08:37 AM   #9
electures's Avatar
service upgrade
Newly licensed
Congradulations!! I teach electric @ PennTech. Check out www.njeg.org for your CEU classes. I'll PM you my contact info.
Sizing motors
Questions regarding 100amp service and panel upgrade asledge Electrical 38 12-13-2012 12:57 AM
New Service Entrance Cable to be installed. Upgrade to 200amp? Joeboo25 Electrical 32 09-21-2012 06:57 PM
Questions about a service upgrade. Just don't want house to burn down. danielrg Electrical 16 09-04-2011 10:00 PM
Upgrade to 200amp service? twalber Electrical 3 07-29-2011 07:41 PM
Garage and service upgrade rough inspection questions WillK Electrical 7 05-25-2011 09:49 PM
