Service Replacement Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 07:03 AM   #1
Rewards Points: 77
Am going to be replacing my 200A service from head to panel. Currently I have 2-0 coming out of the bottom of my meter pan, going straight through my cinder block wall, then into bottom end panel of my load center. The cable is wrapped I guess a mid-1960's Romex. I'd like to use 2 1/2 NM tubing to run my 2-0 Cu lines in, using an LB to lead the wires through the block. Inside I'd like to enter the top of my new QO panel for neatness, however to accomplish this I'd need a total of 3 condolets for a total of 270 deg of bends. Not sure if A) I want this many turns and B) How easy it's going to be to get (3) 2-0 cables in a condelet.
Any thoughts?
Thanks!
Mikenra is offline   Reply With Quote
Old 01-16-2012, 07:18 AM   #2
Julius793's Avatar
Originally Posted by Mikenra
Am going to be replacing my 200A service from head to panel. Currently I have 2-0 coming out of the bottom of my meter pan, going straight through my cinder block wall, then into bottom end panel of my load center. The cable is wrapped I guess a mid-1960's Romex. I'd like to use 2 1/2 NM tubing to run my lines in, using an LB to lead the wires through the block. Inside I'd like to enter the top of my new QO panel for neatness, however to accomplish this I'd need a total of 3 condolets for a total of 270 deg of bends. Not sure if A) I want this many turns and B) How easy it's going to be to get (3) 2-0 cables in a condelet.
Any thoughts?
Thanks!
Is it gona be copper wire?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-16-2012, 08:05 AM   #3
Rewards Points: 77
Oopps sorry. Yes copper
Old 01-16-2012, 08:06 AM   #4
Julius793's Avatar
Don't see any code violations I think you will be fine pulling it especially with an lb
Old 01-16-2012, 08:15 AM   #5
Rewards Points: 77
Thanks ver much. I don't see any code violations either, I'm just wondering if mechanically it sounds sensible.
Old 01-16-2012, 04:57 PM   #6
Licensed Pro
Why not just mount the QO panel with the main on the bottom and enter through the bottom. Same neatness achieved and a WHOLE lot easier to route the 2/0 wires.
The Following 2 Users Say Thank You to HouseHelper For This Useful Post:
frenchelectrican (01-16-2012), Speedy Petey (01-16-2012)
Old 01-16-2012, 04:59 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Totally!
It makes absolutely NO sense to go out of your way to keep the breaker on top, just because that is the way people are used to seeing it.
Old 01-16-2012, 05:01 PM   #8
Originally Posted by Mikenra View Post
......, however to accomplish this I'd need a total of 3 condolets for a total of 270 deg of bends.
LB's do not count towards bending limitations.
And 2-1/2" is pretty big for three 2/0. 2" is plenty.
Old 01-16-2012, 09:02 PM   #9
Rewards Points: 77
Thank you all do much. Perfect idea mounting upside down!
Old 01-16-2012, 10:39 PM   #10
Remember, if the main breaker moves side-to-side there is no such thing as upside down.
Look at all the writing on the cover, panel and breakers. Everything reads side-to-side.
Brick Windowsill replacement question scottjgibson Building & Construction 2 07-19-2011 10:48 AM
Service Entrance Wire Question ricprice Electrical 4 06-16-2011 10:26 AM
service entrance question brianpk Electrical 5 05-22-2011 09:44 PM
Dielectric Nipple Replacement Question - Water Heater sicilian97 Plumbing 5 03-15-2011 10:15 AM
Siding replacement question MeatballCB General DIY Discussions 16 02-05-2010 02:53 PM
