Service Panel-Transfer Switch Distance - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 08:39 AM   #1
Im installing a SQ D (QO) 200a service panel (new construction/ basement) along with a Generac 70a E-Z prewired Transfer Sw (8Kw gen).
Q: The transfer sw comes with 30" of watertight 1.5" conduit (for connection to 70a breaker is service panel). I need the panels closer together; more like 6" apart. I would like to cut this conduit down to 6" then feed the wire back through and mount.
Is there a min distance that the panels need to be apart? I have the required 30-36-6 working space for the service panel and the door for it swings opposite the transfer sw (which has no door). Reason i ask is that i found it peculiar that the conduit was 30" and thought maybe this is for working space requirement (even then it would only need 15"). Anyway- I didnt think that applied to other electrical components and panels; only other stuff.
usmc124 is offline   Reply With Quote
Old 06-10-2012, 09:02 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You can shorten them as much as you need.
Old 06-10-2012, 09:32 AM   #3
Thanks for the "boost"
Old 06-10-2012, 09:53 AM   #4
Yeah, for some reason they seem to think every transfer panel install requires the same distance flex.
Tags
service panel , transfer switch , working space
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 09:18 AM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 08:45 PM
