Service Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 08:13 AM   #1
Hello,
I have an old screw in fuss panel that I want to update to a circuit breaker panel. The sheet on the panel door said it is 100 amps serivice but the main pull out fuss has 2 60 amps fusses. The wire comming from the pole all the way to the fuss panel is #3 wire which is for 100 amps. Is it ok to get a panel with a 100 amp main breaker?
Matt
matta25 is offline   Reply With Quote
Old 10-23-2013, 08:18 AM   #2
Rewards Points: 13,724
Post a picture of the panel.
Old 10-23-2013, 08:34 AM   #3
Here is the picture of the panel door:
Old 10-23-2013, 08:40 AM   #4
This is the photo of the panel:
Old 10-23-2013, 09:04 AM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If it's #3 copper, you'll need to go to 100 amps.
wirenut1110 is offline   Reply With Quote
Old 10-23-2013, 09:06 AM   #6
Rewards Points: 510
The code lists #3 @ 110 amps AND they list it in 240.6 as a "standard breaker" but I've never seen one
Old 10-23-2013, 09:12 AM   #7
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,166
Don't do like me and melt the wires from the pole to the house.
100 amp wires in the mast but smaller wires coming from the pole.
POCO changed the wires for no cost. The guy said they should have been larger.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 10-23-2013, 09:21 AM   #8
Rewards Points: 510
Just googled it and they do make them. Still have never actually seen one.
Old 10-23-2013, 09:32 AM   #9
Thank you guys for the help. I had a tree cut down last year and when they were cutting it, it fell and hit the wire comming rom the pole and ripped my mask and meter base from the house. They put a new box meter base in (the old one was round) and in know the wire is #3 copper all the way to the pole to the panel.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 08:00 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 08:39 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
