Service Panel Grommet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 01:32 PM   #1
Service panel grommet
The gromet in my panel has a tab on it that presses on the wire presumably to keep the wire from pulling out. I need another one and bLowes only has the round type that you might use for metal studs. I suppose it would protect the wire but is this sufficient for the panel or is the type with the tab a requirement?
toobhed is offline   Reply With Quote
Old 08-16-2011, 01:35 PM   #2
Code05's Avatar
Rewards Points: 1,104
Yes you need the tab. Just use a regular romex connector or stop by a supply house.
Code05 is offline   Reply With Quote
Old 08-16-2011, 02:13 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The tab is what secures the cable to the box. Replace the connector as stated earlier.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2011, 03:00 PM   #4
Thank you!
Old 08-16-2011, 04:34 PM   #5
electures's Avatar
Originally Posted by toobhed View Post
Thank you!
welcome.
Old 08-17-2011, 07:25 PM   #6
I found a metal clamp that the guy at the store told me would work. Does this look like the right one and can I put two wires through it?
Old 08-17-2011, 07:29 PM   #7
Code05's Avatar
Looks like the right clamp. Most are rated for two cables depending on the size and type? What cables are you installing?
Old 08-17-2011, 07:36 PM   #8
It's 12/2
Old 08-17-2011, 07:40 PM   #9
Code05's Avatar
It's 12/2
You are fine with two 12/2 cables in that connector.
Old 08-17-2011, 08:14 PM   #10
electures's Avatar
Without knowing the manufacturer, I can't say if it is rated for two cables. I personally do not install two cables in that type of connector. When I need to double up cables I prefer the T&B 3201 plastic connector
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 04:42 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 08:35 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
New service panel + Generator transfer Nhrafan Electrical 1 04-22-2008 12:05 AM
