-   -   Service panel grommet (http://www.diychatroom.com/f18/service-panel-grommet-114226/)
toobhed 08-16-2011 12:32 PM
The gromet in my panel has a tab on it that presses on the wire presumably to keep the wire from pulling out. I need another one and bLowes only has the round type that you might use for metal studs. I suppose it would protect the wire but is this sufficient for the panel or is the type with the tab a requirement?
Code05 08-16-2011 12:35 PM
Yes you need the tab. Just use a regular romex connector or stop by a supply house.
electures 08-16-2011 01:13 PM
The tab is what secures the cable to the box. Replace the connector as stated earlier.
toobhed 08-16-2011 02:00 PM
Thank you!
electures 08-16-2011 03:34 PM
Originally Posted by toobhed (Post 708622)
Thank you!
welcome. :thumbsup:
toobhed 08-17-2011 06:25 PM
I found a metal clamp that the guy at the store told me would work. Does this look like the right one and can I put two wires through it?
http://i1181.photobucket.com/albums/...d/df333268.jpg
Code05 08-17-2011 06:29 PM
Looks like the right clamp. Most are rated for two cables depending on the size and type? What cables are you installing?
toobhed 08-17-2011 06:36 PM
It's 12/2
Code05 08-17-2011 06:40 PM
Originally Posted by toobhed (Post 709543)
It's 12/2
You are fine with two 12/2 cables in that connector.
electures 08-17-2011 07:14 PM
Without knowing the manufacturer, I can't say if it is rated for two cables. I personally do not install two cables in that type of connector. When I need to double up cables I prefer the T&B 3201 plastic connector
