Service Panel And General Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 06:27 AM   #1
Service panel and general questions
I am adding a couple circuits for a basement finish.
Is it required to shut off the power before hooking up the common to the bus bar?
also can two seperate GFCI circuits and a light switch share the same common?
reddman is offline   Reply With Quote
Old 05-11-2009, 08:27 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Turn the power off if it makes you feel better!
If you are talking about two gfci breakers, then the answer is no.
If you are talking about gfci receptacles, then the answer is maybe.
We need more details on the gfci.
Old 05-12-2009, 04:51 AM   #3
they are going to be recepticles.....
I knwo the service has an A and B side so I am putting both circuits on top of each other.
Thanks for any help
Old 05-12-2009, 11:54 AM   #4
Rewards Points: 204
They should not.
Nuisance tripping may occur. I have seen it happen and it is a pain to find if you are not the one who installed it. Keep them separate.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
PV panels - general questions. Clutchcargo Green Home Improvement 3 04-08-2009 09:53 AM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
