Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 08:04 AM   #1
service panel
i have a 100 amp main panel and would like to put in a 60amp service panel in what type wire do i need?
mike_l is offline   Reply With Quote
Old 05-17-2009, 08:21 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
OK, I totally don't get it. The 100A main IS your service panel.
Are you wanting to install a sub-panel?
If so then you'll need to give us a few more details. The most important being where will the sub be?
Old 05-17-2009, 08:31 AM   #3
Rewards Points: 2,350
Sub-panels have to be the most frequently rehashed topic here. Do a search, then come back with specific questions.
Old 05-17-2009, 10:15 AM   #4
the sub -panel will be right next to the main panel the main panel is full
im adding a room to house and i dont want to use any more tandem breakers
Old 05-17-2009, 10:22 AM   #5
Read up here and let us know if you have any questions.
http://www.diychatroom.com/search.php?searchid=781088
Old 05-17-2009, 12:06 PM   #6
Rewards Points: 78
Search and read for days. Guarantied!
Old 05-17-2009, 12:27 PM   #7
what i dont understand is how do i come off the main panel(when its full) to feed the sub-panel witch will be 60 amp
Old 05-17-2009, 02:46 PM   #8
Mike you are going to have to open up two spaces on your main panel and maybe add them to your sub panel once it's in.
Paelectrican is offline   Reply With Quote
Old 05-17-2009, 03:10 PM   #9
Exactly. Move two circuits, or one 240v circuit, from the main over to the new sub-panel.
Old 05-18-2009, 01:56 PM   #10
Just do it right and change the panel to a suitable size. Adding crap to crap just makes a big pile of crap.
220/221 is offline   Reply With Quote
Old 05-18-2009, 03:40 PM   #11
I disagree, and I think many would agree.
A sub-panel is a perfectly acceptable solution. IMO just changing the panel is half-assed. If you are going to go through all that just do a service upgrade to 200 with a full sized panel.
Old 05-18-2009, 03:58 PM   #12
Changing the panel will also clean up a lot of issues common in outdated overfilled panels.
In a lot of cases it's not a lot more work/money than adding a sub., ESPECIALLY if it is one of those basement installed panels with the cabling all exposed. You could do the job in the same amout of time it would take to install a sub.
You'd have all new breakers @ $4 a piece and all conductor connections would be fresh and tight.
More than likely his original panel is small, old and over filled. Now he will have to reroute a couple circuits from there to make room for the new sub feed which will probably just add to the mess.
Keep it simple. Take it out and install a bigger panel
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
new service panel The Barber Electrical 1 05-16-2008 06:49 PM
New service panel + Generator transfer Nhrafan Electrical 1 04-22-2008 12:05 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
