Service Line Tree Hugger - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2008, 09:45 AM   #1
Service line tree hugger
When the local utility connected a new service next door, they routed the service line to that house directly up against the trunk of a large pecan tree, deflecting the line about 6". Some of the bark on the tree is being lifted off where it's touching it. Question is, isn't that against the NEC code unless they have a protective sheathing added over the portion of the line that's touching the tree?
TcatTexas is offline   Reply With Quote
Old 07-23-2008, 09:52 AM   #2
Rewards Points: 126
The utility does not follow the NEC. But what you have described is a safety issue. Have you contacted the utility. Or better yet the commission.
Old 07-23-2008, 09:56 AM   #3
Thanks J.V.
I will contact them and let them know. They left the neutral leg off of my house during this install too, so I'll be pointing out to them the lack of attention on this entire job.
Old 07-25-2008, 11:15 AM   #4
Rewards Points: 126
Good Luck.
Old 07-25-2008, 06:30 PM   #5
Master Electrician
JohnJ0906's Avatar
Did the utility use one of it's own crews for this, or did they use a subcontractor?
The POCO here uses subcontractors at times, and the level of training for them can be somewhat.... uneven.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Gas line service BillyD Plumbing 1 05-03-2008 06:33 PM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 10:10 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
