Service Line From House To Garage.... Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 09:12 PM   #16
Thanks again InPhase!! I think I've got it all fleshed out then. You and the others have been terrific help and a great resource for me. Thanks again.
I feel much more confident now in completing the job.... Have a great week!
Todd-sta is offline   Reply With Quote
Old 11-09-2008, 11:02 PM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by Todd-sta View Post
Thanks Jamie....
I'd prefer copper, and that's what I think I'll go with... but pricing out a few places - it came to $1200 roughly for 135 foot of #2 X 3 wires (not including the ground wire - are the ground wires cheaper ?)
But I haven't checked Home Depot yet.
If I can get it for the price you stated - I'm all over that!!
Aluminum is very tempting.... but I know you have to use a thicker wire to get the same benefits as a thinner copper....
Thanks for your input.
The $1.78 per foot for #2 THHN was the price they gave me yesterday when I called to check on some wire prices. Normally #6 is the largest you run for ground, and I belive you can run #8, so yes, it would be a bit cheaper than the other feeder lines. Based on the prices home depot told me yesterday, you should not be much over right about 700, even with the ground wire. Unless my calculations were way off... It sounds like the price you were quoted for wire was much higher than the price my local home depot gave yesterday.
Good Luck
Jamie
jamiedolan is offline   Reply With Quote
Old 11-10-2008, 02:24 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If your shopping home depot you might wan to check out the price on al mobile home feeder in #2. It will be 2-2-2-4 and is USE-2 direct burial or conduit. As Chris said it will be protected by a 90 amp breaker as per code for a sub-panel. Looks like this...
Old 11-10-2008, 07:29 AM   #19
Thanks guys! I will check both out today!! Hope to get this hooked-up and completed shortly. Be nice to finally get power out there...!! I attached a picture in case you didn't see the project from "my pictures." Just for your visual info.
Old 11-10-2008, 11:20 AM   #20
I just purchesed 450 feet of 1/0 THWN from a local electrical supply house and it was just $697.00
Rbeard is offline   Reply With Quote
Old 11-10-2008, 11:34 AM   #21
I guess I lied....LOL.... I do have just a few more questions...
  1. What kind of terminal connector/block/device do I need just inside the house to connect the incoming #2 THHN wire to the #2 SE wire which will run from that point to my house' electrical panel?
  2. Considering that I will be using #2 SE copper wire to go from just inside the house to the house's panel.... what kind of "connector" do I need (ala romex connector?) to secure the #2 SE cable/wire as it enters a knockout in my house's panel??
  3. Are the knockouts in the typical 150 amp panel large enough to accomodate #2 Se cable/wire coming into it?
  4. Also - what's the difference between #2 and #2/0 wire? Just curious.
Any advice you can give me regarding the connection of the #2 THHN wire coming from the outside garage to the #2 SE cable just inside the house, and connecting that securely to my 150 amp panel would be very appreciated.
Thanks again guys...
Old 11-10-2008, 12:29 PM   #22
Rewards Points: 2,350
I do believe a 1-1/4" "romex" connector will be OK for #2 SER. As for the connection between inside and out, I prefer to use "polaris taps" from NSI Industries, or similar. They are available at any electrical supply house.
Old 11-10-2008, 01:00 PM   #23
InPhase -
Thanks for the reply -
I looked up the Polaris Taps on the web... makes sense... but, don't they have to be encased in some sort of enclosure?
Probably a dumb question by me....
Old 11-10-2008, 01:11 PM   #24
InPhase -
Yes. While you're at Home Depot, pick up a PVC junction box. They are near all the PVC stuff. Get a 6 x 6 x 4, or 8 x 8 x 4, or whatever they may have that is large enough.
Old 11-10-2008, 01:23 PM   #25
Great - I'll do it. Thanks again InPhase!!
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
New House and Shop Building Service Rbeard Electrical 9 11-07-2008 04:19 PM
Next Question, Sub panel in detached garage... OmegaBunny Electrical 5 09-16-2008 12:37 AM
Sub feed house from new garage JAYRAN Electrical 10 10-02-2007 07:08 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
