Old 01-29-2012, 09:31 PM   #1
service in house
hi all just wondering what service i have to the small panel on the left , i think you take the breakers at face value and not add them together , which would mean 50 amp service.
meter says 100 on it , so heres a few pictures ,
my goal is to run a line from my panel eventually and get the 240 so i can run a shop heater.
dryer in my house is gas so i still need to save room for upgrading that in the future as well.
ex-28 is offline   Reply With Quote
Old 01-29-2012, 09:41 PM   #2
Julius793's Avatar
service in house
If that's coming off the meter it's a 50a service.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-29-2012, 09:44 PM   #3
service in house
ya from the meter it goes directlly to the small box on the left
so i take the breaker at face value then , 50 amp service. so in my case if i want a 240 in garage , i have to get eletrician to change wire from meter to the panel. ?
Old 01-29-2012, 09:47 PM   #4
service in house
the thick red wire says , type tw 600v on it , if its any help.
Old 01-29-2012, 10:00 PM   #5
Master Electrician
service in house
I don't think we've gotten the whole picture here.
brric is offline   Reply With Quote
Old 01-29-2012, 10:03 PM   #6
service in house
power from meter outside comes into the smaller panel with the 2 50 breakers on it , then feeds the bigger panel on the right.
Old 01-29-2012, 10:11 PM   #7
Master Electrician
service in house
I'll have to take your word for it since it is impossible for any of us to make a determination from the photos shown.
Old 01-29-2012, 10:30 PM   #8
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
service in house
Looks from your picture you have 50 amps if you want 240 in the garage an electrician could add a double pole breaker and run power to the garage.
But you at max can draw 50 amps by what I see. You can't just change wires from meter to main panel and start drawing 100 amps. You have to make sure that the wires feeding your meter and your meter socket can handle 100 amps. And those wires in the main panel don't look like they can do 100 amps.
Also the larger panel is actually made a sub panel and I think it should be fed by four wires from your main rather than three. And the neutral and ground separated.
Yes you could run 240 to the garage but many things to consider if you decide on upgrading to make sure it's properly wired and able to handle what you are considering. Best thing to do would be call an electrician and have them take a look. Hard to tell from pictures.
rrolleston is offline   Reply With Quote
Old 01-29-2012, 10:34 PM   #9
service in house
yes , going to have to have an electiction come out and take a look , apprecite the info alot !
Old 01-29-2012, 10:48 PM   #10
rrolleston's Avatar
service in house
You could also take a picture inside the larger panel if you feel comfortable after turning off the smaller panel. That way if you have any other questions we can try and help. Please let us know what an electrician says.
Old 01-29-2012, 10:50 PM   #11
service in house
not a problem can post a picture inside other panel tomorrow thanks again !
Old 01-29-2012, 10:56 PM   #12
Licensed electrician
service in house
You might want to consider changing out the FPE panels.
Old 01-30-2012, 01:51 AM   #13
service in house
Call your power/utility company ask what the max size service in amps, they are currently providing, or will provide at no additional cost 100a 150a or 200a. Figure out your needs and budget. Go with a single panel 100a or 200a call a professional done.
Knauer is offline   Reply With Quote
Old 01-30-2012, 04:08 AM   #14
service in house
Yah Knauer, I am agree with you. Utility company be the problem. Once I also had the same problem at that time I had done energy company comparison with another utility company and found that Public Utility Brokers is the best one.
agate is offline   Reply With Quote
Old 01-30-2012, 11:10 PM   #15
service in house
You've got to change that Federal Pacific panel. It's a model that is known to be defective, and UL has rescinded the listing on it. It's very dangerous.
fa_f3_20 is offline   Reply With Quote
100amp house service enough for 50amp spa? paskracing77@ho Electrical 4 09-15-2011 08:20 AM
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-13-2011 12:30 AM
installing vinyl siding around an electrical service on an older house huntercrow Carpentry 5 01-28-2011 05:12 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 08:45 AM
