Service Entrance Wire Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 06:05 PM   #1
Cool
I purchased a lot in SW Missouri (Cedar Co.)- the meter will be on a pole at the front of the lot. I would like to build to the back, about 600' from the meter. So with that in mind -
  • would like to bury cable to supply house
  • will trench
  • will have 200 AMP Service at meter.
1. Would like to Direct Bury (no conduit)
2. What type/Size of wire should I use to create this run?
3. Will go from meter to a Main box in a pump Shed
4. Understand from reading here - that 4 wires must be used? Not sure how to connect the ground, as it would parallel the Neutral - not sure why that would be required...
5. Is my plan sound for this application? Cannot find appropriate charts to give me acceptable length for this application... thinking I will need a 4/0 setup, but can't confirm. Initial load will be several campers - 30 Amp each - but plan on retirement house in 5 yr.
Any help would be appreciated.!
ricprice is offline   Reply With Quote
Old 06-15-2011, 09:53 PM   #2
Missouri Bound's Avatar
750mmca...it's quite heavy. Can you have the power company add a pole (or 2) and move the meter closer to the building site?
Old 06-16-2011, 10:15 AM   #3
Post
Service Entrance
Thanks for replying ! I do not know what chart you looked at or how you got that answer - can you direct me to that information?
About the pole - I can - however - aesthetics say no.
Old 06-16-2011, 10:42 AM   #4
Master Electrician
Rewards Points: 3,698
You must account for a substantial voltage drop for a run of 600'. The wire size should be increased accordingly. I come up with 2 paralled 600 kcmil per conductor(6 conductors for 240 volt single phase) for a 3% voltage drop.
brric is online now   Reply With Quote
Old 06-16-2011, 11:26 AM   #5
if estthetics are issue , electric company with run service underground. but they charge more for that. i also live in central mo. crawford electric is my power comapany & they wanted 5-6 grand fpr underground service.
hope this helps
now youe pain im trying to get power to pond a 1000 ft away without having to look at the poles
good luck
jshepp is offline   Reply With Quote
Tags
service entry question
Questions about service entrance maple_john Electrical 20 04-02-2011 03:22 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 01:59 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
2 wire service and laptop computers gregdonovan Electrical 9 06-11-2009 01:42 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
