Service entrance wire
1K views 1 reply 2 participants last post by  Code05
#1 · (Edited)
When last I posted here, I had finally got my rough inspection passed:
http://www.diychatroom.com/f18/finally-108400/
Today, just short of 2 months later, the POCO finally moved their connection to my new service entrance.
I have a question though... I'm using 4/0 aluminum for everything going to the panel as required by code, as I understand it. And I knew to expect that an overhead line can be smaller. But my 4 gauge solid aluminum wire that was being used when I had 100 amp service is the same wire that they moved over and connected to the 200 amp service.
(I think it's 4-gage, I only really had a tape measure on hand for measuring, so I measured the wire as being about 3/16" diameter. That's wire without insulator, with the insulation it was 5/16" and I could see it was solid and not stranded.)
I've read elsewhere of 1/0 being used for 200 amps, and that this is the POCO's jurisdiction and isn't covered by NEC... And I know that overhead wire can be smaller because it gets more cooling from air that can be moving, but this is a huge difference in size and I can't help feeling a little uncertain as to whether this is really right...
