Service Entrance Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 09:56 PM   #1
Rewards Points: 201
Service entrance wire
Is single conductor wire (type THHN, size 3/0) ok for service entrance conductors for a 200 amp service panel, or does the service entrance conductors have to be sheathed in a cable ?
And can the conduit from the meter box to the service panel be pvc or does it have to be metal ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 05-23-2011, 12:11 AM   #2
Mad Scientist
3/0 is good for a 200A service, assuming it's copper. Single conductors in conduit are acceptable everywhere, as far as I know. Requirements for the conduit from meter pan to panel can vary depending on your specific locale. Usually this is good question to ask your local electrical inspector.
McSteve is offline   Reply With Quote
Old 05-23-2011, 07:15 AM   #3
Electrical Contractor
kbsparky's Avatar
When using copper conductors for a 200 Amp residential service, #2/0 is sufficient.
You CAN use #3/0 but unless you are fully loaded, the upsize is a waste of resources.
Installing type THHN/THWN in a conduit is perfectly acceptable. Check your local requirements and restrictions before using PVC however. PVC would not be appropriate in places that have extreme cold, such as Alaska and some northern areas. The PVC can become quite brittle and shatter in such harsh environments.
-KB
Still confused on garage and service entrance wires... WillK Electrical 19 04-29-2011 06:12 AM
New upgraded 200A service wire connections WillK Electrical 1 04-28-2011 02:02 PM
The service entrance move and upgrade to 200 A WillK Electrical 2 04-21-2011 04:42 PM
200 amp service entrance cable size Chuck S Electrical 7 01-08-2011 10:17 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
