Service Entrance Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 11:34 PM   #1
So my boss has a ranch house that has increased in size over the years. My question is about the way the power company ran power from the transformer to the meter pole. There is a total of 6 wires running from the transformer to the meter pole. 2 for one leg, 2 for another, and 2 for the neutral. I'm not sure of the gauge but my guess is 8AWG. Is this a legal run or was the power company too lazy to run them correctly, so they just added on to the existing wires to make a heavier gauge? I have serious doubts about this setup, what is one run were to weakin and burn up? Then all the power must flow through the singal remaining wire which could then burn up as well. Any input would be great.
KempDobro is offline   Reply With Quote
Old 04-06-2010, 12:02 AM   #2
Master Electrician
parallel runs...we use them all the time in a commercial setting. i doubt the wires are number 8's though i'd be interested in finding out for sure. I don't know if the same rules apply for residential dwellings and parallel runs though.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
KempDobro (04-06-2010)
Old 04-06-2010, 07:52 AM   #3
Master Electrician
Rewards Points: 3,766
Power companies are not governed by the NEC.
brric is online now   Reply With Quote
Old 04-06-2010, 03:45 PM   #4
I know NEC doesnt over see power companies doings, but there has got to be someone who keeps an eye on their methods and practice. Any Ideas?
Old 04-06-2010, 03:51 PM   #5
Master Electrician
Why do you think there is something inherently wrong with the installation? As stated above it's done all the time for higher amperage installations. What if they were larger single conductors and one was lost ? There would still be a problem. What is your concern?
Old 04-06-2010, 03:58 PM   #6
well one set of wires is obviously much older than the other, it shows. Meaning the older one is more fatigued. What if it reaches the point where it doesn't work anymore? the remaining smaller wire is then required to carry a much heavier load. He has a very large house and two very large barns, each 200 amp setups all dependant on this parrallel run. Not to mention the two large water well pumps up the hill.
Old 04-06-2010, 04:02 PM   #7
Master Electrician
Post some photos.
Old 04-06-2010, 05:20 PM   #8
Master Electrician
most likely there was a 200A service and a second was added later on...hence the two seperate runs and the age difference in the utility side feeds...as brric says there's nothing to worry about.
Old 04-06-2010, 05:30 PM   #9
just to add most probaly already know but they can also get away with such small wires because they are free air conductors which hold higher amp vaule as stated in the nec
chris0914 is offline   Reply With Quote
Old 04-06-2010, 06:18 PM   #10
Master Electrician
number 8's still are nowhere near big enough to take on 200A(parallel run)....depending on distance to service from pole and not having my code book infront of me i'd wager at roughly a #2 needed for a 200A feed free air. with a set of 2/0 copper joined to them at the mast head(parallel copper run as well). I have a feeling that might be wrong....i'm sure someone will set me straight though .
Old 04-06-2010, 11:36 PM   #11
ok. well it will a week or two before i can get the gauge, i'm currently away. I'm pretty interested in knowing the exact gauge of the parallel runs too because the overhead wires run from the meter to the barns are 8 gauge aluminum. Those spand about a hundred feet each.
general service panel question about ground / neutral BlueBSH Electrical 3 03-17-2010 07:55 PM
Service Question MyFriendMo Electrical 5 01-08-2010 10:27 AM
Service entrance ground size ? banks10 Electrical 4 12-18-2008 06:20 AM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
