Service Entrance Ground Size ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 11:34 PM   #1
Service entrance ground size ?
What size ground wire is needed for 200A single phase service
I'm using 3/0 copper for my conductors
banks10 is offline   Reply With Quote
Old 12-16-2008, 12:22 AM   #2
I could be wrong, but according to this site, #4 is required
http://www.jhlarson.com/ind_tables/g...calc_25066.htm
joey b is offline   Reply With Quote
Old 12-16-2008, 12:44 AM   #3
Thanks Joey B. I bought #2 so now I know I'm within the requirements of the NEC
Old 12-16-2008, 11:40 AM   #4
Rewards Points: 160
When you say ground wire, exactly what do you mean? The wire that goes to the ground rod? Water pipe?
If the answer is yes #4 is all you need. But #2 is even better.
Old 12-18-2008, 05:20 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I agree, there is no "ground" wire, as in equipment ground. Also, a conductor that is going only to a ground rod is only required to be #6cu regardless of service size.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
how determine size of service tikicarver Electrical 2 01-29-2008 08:10 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
