Service entrance
Not an electrician but hard to say- in my residential area (most of the time!) Power company supplies wiring to the building in an aerial installation- homeowner is responsible for wiring from there (roofline) down to the meter and within home. Also in my area, underground installations for a residence the poco runs feeders connections and is responsible up to the meter. Homeowner is responsible from meter inward.
If wiring is substandard to the meter the poco should be called for evaluation and potential replacement. No residential building today should be wired with <100A, absolute minimum. Does this cabin have comfort conveniences? Are you expecting to use/install some? Do an assessment for what is used here electrically to determine what you might need in your service, it should then be wired accordingly.
Did you ever stop to think, then forget to start again?
