-   -   Service entrance (http://www.diychatroom.com/f18/service-entrance-39956/)
dcwestcott 03-09-2009 01:38 PM
Service entrance
I'm upgrading my older cabin, and I have a question on the service entrance. The Power company says I have a 30 amp single phase service. When I open my main breaker box I see a 100 amp breaker. This is weird!
What I'm afraid of is that the wiring from the meter up to the power company connection is sub standard. Is there a standard cable or wire size that must be used for the service entrance?
I can get the power company to come out and disconnect me for a day while this is done, but I want to be sure I'm putting in the right wires!
Any special tricks/requirements for the power company connection?
handyman78 03-09-2009 04:57 PM
Not an electrician but hard to say- in my residential area (most of the time!) Power company supplies wiring to the building in an aerial installation- homeowner is responsible for wiring from there (roofline) down to the meter and within home. Also in my area, underground installations for a residence the poco runs feeders connections and is responsible up to the meter. Homeowner is responsible from meter inward.
If wiring is substandard to the meter the poco should be called for evaluation and potential replacement. No residential building today should be wired with <100A, absolute minimum. Does this cabin have comfort conveniences? Are you expecting to use/install some? Do an assessment for what is used here electrically to determine what you might need in your service, it should then be wired accordingly.
dcwestcott 03-09-2009 05:22 PM
Summer Cabin
This is a summer cabin, That may get used a little in the winter. So no air condition, just thestandard appliences.
I will do a power survey of useage in the cabin. Good Idea. Thanks:no:
NolaTigaBait 03-09-2009 07:11 PM
i've seen 4 plexes have a drop size of #6 aluminum!....they have different standards as far as wire size
