Service Drop Wire Gauge - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 11:09 AM   #1
Rewards Points: 160
Sometime before I purchased my house the panel was upgraded to 200 amps (years and years ago). However, looking at the overhead wires coming in from the pole, they look to be a significantly smaller gauge than the wires dropping into the meter base. Is this normal, or should I have my power company install new wire from the pole?
matt151617 is offline   Reply With Quote
Old 02-15-2013, 11:19 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yes it's normal POCO has their own rules and regulations as far as overhead aerial runs go.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-15-2013, 11:19 AM   #3
Most overhead wires will always be smaller sized than the wires at your service drop this die to the big electrical companies not being ruled by the national electrical code also. Since the wires are aluminum and suspended in the air they can carry a larger load
RAUL HIDALGO is offline   Reply With Quote
Old 02-15-2013, 01:07 PM   #4
Electrical Enthusiast
Rewards Points: 504
As others have said, overhead wires used by the POCO are usually smaller. If you look closely, you can see the size of the wires entering your service drop are larger than those coming from the transformer.
Nothing to worry about.
Kyle_in_rure is offline   Reply With Quote
Old 02-15-2013, 02:11 PM   #5
rrolleston's Avatar
Only reason they installed larger size service wire for our home is that we were planning on electric heat and electric tankless water heater. Only time they replace the overhead wire in a service upgrade is if you give them a load calc that shows you will be using a lot more power. But I see many upgrades where people don't use much more than they did before the upgrade.
200 amp service with 100 amp service wire JBeach4343 Electrical 3 08-27-2012 12:18 PM
Can 14 gauge wire be used on 20 amp circuit? diyer111 Electrical 9 08-13-2012 10:14 AM
Drop Wire (From Weatherhead to Meter) roadman1977 Electrical 7 12-24-2011 11:35 AM
Service drop too low above garage WillK Electrical 1 09-19-2011 12:00 PM
What wire gauge for plumbing ground? bob22 Electrical 4 04-04-2010 07:01 PM
