Service Drop Wire Gauge
4K views 4 replies 4 participants last post by  rrolleston
Sometime before I purchased my house the panel was upgraded to 200 amps (years and years ago). However, looking at the overhead wires coming in from the pole, they look to be a significantly smaller gauge than the wires dropping into the meter base. Is this normal, or should I have my power company install new wire from the pole?
#5 ·
Only reason they installed larger size service wire for our home is that we were planning on electric heat and electric tankless water heater. Only time they replace the overhead wire in a service upgrade is if you give them a load calc that shows you will be using a lot more power. But I see many upgrades where people don't use much more than they did before the upgrade.
