Old 04-07-2009, 02:39 PM   #1
Whatamess
Service Disconnect
Per the drawing attached should the neut./ ground be bonded in the circuit breaker box or just the disconnect?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 04-07-2009, 03:05 PM   #2
My License Ain't 4 Sale..
Service Disconnect
Bond in the first disconnect, and carry 4 wires to the panel.
Old 04-07-2009, 03:08 PM   #3
Service Disconnect
Thought I agreed, but now I'm not sure... If your disconnect is unbonded, you may be ok being bonded in the panel. The key is to be bonded in one location only.
Addicted is offline   Reply With Quote
Old 04-07-2009, 04:16 PM   #4
Saftety First!
Service Disconnect
I think per NEC it has to be bonded in first disconnect.
loyal is offline   Reply With Quote
Old 04-07-2009, 06:55 PM   #5
Service Disconnect
Pardon my ignorance, I'm assuming bonding means tying the neutral and ground together? Also, in the drawing it appears that in the breaker box the neutral (light wire?) is bonded to the ground wire and one of the HOT wires???? Maybe, just the way it's drawn???
Mike in Arkansas is offline   Reply With Quote
Old 04-07-2009, 06:58 PM   #6
Service Disconnect
It's pretty simple ..read above
NolaTigaBait is offline   Reply With Quote
Old 04-07-2009, 07:03 PM   #7
BIGRED
Service Disconnect
InPhase277 is correct for the daily 2-bit prize
Grampa Bud is offline   Reply With Quote
Old 04-07-2009, 10:51 PM   #8
Whatamess
Service Disconnect
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Service Disconnect Height jamiedolan Electrical 13 03-11-2009 06:30 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
New Service msagers Electrical 1 02-13-2008 03:08 PM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 08:43 AM
