Service Connector With Teflon On Threads? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:32 PM   #1
service connector with teflon on threads?
When installing a rain tight service connector where the service cable enters the meter box do you use teflon or pipe dope on the connector threads to help prevent water infiltration? I cant help but think water might possibly enter the base of the connector and seep into the meter box without it.
joe citizen is offline   Reply With Quote
Old 10-27-2011, 09:41 PM   #2
Electrical Contractor
If it helps you sleep better.
Sine is offline   Reply With Quote
Old 10-28-2011, 07:28 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I sleep just fine without using tape or paste on the threads.
Kyle
Old 10-28-2011, 06:08 PM   #4
Licensed electrician
Rewards Points: 1,764
You could use a sealing locknut.
Old 10-28-2011, 06:34 PM   #5
Rewards Points: 1,192
At the topside,I only use clear silicon.And use it to close up holes,ect, over duct seal. Better lifespan.
bobelectric is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
rewire and new service entrance wire dghowery Electrical 4 10-13-2010 08:31 AM
"Moving" service entrance WillK Electrical 4 09-29-2010 01:04 PM
How to tell Service amperage?? Buckley Electrical 2 06-06-2009 05:42 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
