Service Cable Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 12:28 AM   #1
Rewards Points: 109
service cable replacement
I have the old cloth covered service cable on my house. I would like to have it replaced as it is old and water is actually wicking in with this old cable. Is this an expensive fix?
hitmehhh is offline   Reply With Quote
Old 09-28-2010, 01:07 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
define "expensive"
If it can be replaced with SE cable such as you have and nothing else needs to be done, it is not what I would consider expensive
If, for some reason you need to start replacing the meter socket (they can corrode horribly) or your locality deems this to involve enough of the system where you might have to upsize your service, it can get pricey pretty quickly.
what size is your service panel (amp rating of main breaker)?
Old 09-28-2010, 02:04 AM   #3
recently got quoted for replacing meter, panel, & SE, 100A service, for $1500.
acerunner is offline   Reply With Quote
Old 09-28-2010, 05:12 AM   #4
Rewards Points: 1,192
It's time for a upgrade to 150 amp.You can't just replace the se cable.
bobelectric is offline   Reply With Quote
Old 09-28-2010, 12:50 PM   #5
Its up to you but if it were me I would have it upgraded to 200 amp, then you will be covered for anything future you might decide to do. Cost varies but 2000 is about right
SleepyDog is offline   Reply With Quote
Old 09-28-2010, 01:34 PM   #6
Rewards Points: 109
I checked the main breaker it is a 100 amp service. I have an electrician coming over Thursday to check it out.
Service Panel Replacement and 200A upgrade mark_anderson_u Electrical 2 09-10-2010 07:43 AM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Installing new service & weather head. BowDown Electrical 24 06-10-2009 12:24 PM
