Series Or Parallel Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 05:20 PM   #1
Rewards Points: 150
Send a message via AIM to Bocolo
Series or Parallel Outlets
Hello,
The more I read this subject the more I get confused. I have been told (not questioning anyone just tyring to educate myself) that I can wire multiple receptacle outlets either by pigtailing the wires or runing the wires to one set of screws and then from the second set of screws to the next receptacle outlet. Now, if I am understanding what I am reading (which I am probaly not) the only way you can wire in parallel is to use pigtails (??) and if you wire from set of screws to set of screws then you are wiring in series (??). Ok, so where and how does this statement takes effect: "When wires are part of a three wire circuit, it is not permitted to feed the white conductor through by using the two screws on the side of the receptacle because removing a receptacle could place 120 volt loads in series on 240 volts" I am assuming a "three wire circuit" is a 12/2 cable with a ground, or is this where I am mistaken? Thanks for your time and help in advance.
Bocolo is offline   Reply With Quote
Old 02-06-2009, 05:39 PM   #2
All receptacles are wired in parallel. The terms series and parallel are often misused when talking about house wiring. The "three wire" circuits they are referring to are multi-wire branch circuits.
http://ecmweb.com/mag/electric_multi...anch_circuits/
jerryh3 is offline   Reply With Quote
Old 02-06-2009, 05:43 PM   #3
Rewards Points: 150
Thanks for your time and response. So wether you are using pigtails or using the set of side screws you are wiring in parallel? Forgive my ignorance but what exactly are "multi-wire branch circuits". Thanks again for your time.
Old 02-06-2009, 05:50 PM   #4
joed's Avatar
Rewards Points: 13,696
A MWBC is a circuit that use two hot wires and only one neutral. The hot wire share the neutral. The hot wires must be on opposite legs of the service.
The service wires feeding your house work on the same principle. Two hot wires and a neutral.
Old 02-06-2009, 06:12 PM   #5
Yes, either way they are wired in parallel. Check out these diagrams. (They show DC circuits but the principles are the same)
Points 2, 3, 4 would be the brass terminals of the receptacle. 7, 6, and 5 would be the silver.
http://www.allaboutcircuits.com/vol_1/chpt_5/1.html
Old 02-06-2009, 07:17 PM   #6
Rewards Points: 150
Ok. I think I am beginning to understand. Because there are two sets of electrically common points no matter how you wire receptacles they are parallel. To make sure I understand. If I wired three lamps and connected the black source to the black on the lamp 1, then white from lamp 1 to black on lamp 2 and white from lamp 2 to black on lamp 3 then white from lamp 3 to white on source. This will be a series wiring? If any lamp was out the others will not function because of the break in the circuit? Correct? What applications would require to wire in a series if the above is true? Why wire in series? Thanks once more for your time and responses.
Old 02-06-2009, 07:57 PM   #7
I think you got it. Light switches, timers, photocells, are applications of series wiring in residential AC circuits. In DC circuits, batteries, speakers, resistors, can be wired in series for different effects.
Old 02-06-2009, 07:59 PM   #8
joed's Avatar
You are correct. The only thing wired in series in your home is a switch. It is in series with the fixture to be able to turn it off.
Old 02-06-2009, 08:40 PM   #9
Rewards Points: 150
Thanks for all your replies and help. I understand this now.
Series or parallel runronno Electrical 29 07-17-2009 11:40 AM
parallel / series wiring question geetee Electrical 5 06-11-2008 02:42 PM
Diagram of dual hot water heater (s) in parallel not series having flow questions-- timlltt Interior Decorating 1 02-29-2008 03:01 AM
series of troubled outlets Swimmfst Electrical 9 06-14-2006 06:26 AM
Parallel vs. Series Circuit johnson217 Electrical 1 06-19-2005 10:03 PM
