#1 |
Series or parallel
I was just wondering what preference anyone has when hooking up a circuit of outlets, Do you hooked them in series or parallel them with pigtails. I always did them in series but my instructor said to parallel them so if you have a problem with one you won't lose the string. Is there a correct answer to this or just preference. Ron
#2 |
Series or parallel
Watch using the words series and parallel when dealing with househould receptacle circuits. Technically, they are always wired in parellel. I think the use of pigtails is personal preference of the installer.
#3 |
Series or parallel
I like to use pigtails, but if I have no space in the box, I won't use them.
#4 |
Series or parallel
Using pigtail won't prevent losing one receptacle from taking out the others. Instead of having two screw connections you now have one screw connection and one wire nut connection that can fail. I trust screw connection better than wire nut connections. Plus in Canada wire nuts count for box fill.
#5 |
Electrician
Series or parallel |
#6 |
Electrical Contractor
Series or parallel
If the circuit is a multiwire branch circuit, you must use pigtails for the nuetral wire (as per 300.13 (B)).
I got in the habit of wiring all my nuetral connections that way. |
#7 | |
DIY'er
Series or parallelQuote:
Jamie |
#8 | |
My License Ain't 4 Sale..
system. |
#9 | |
DIY'er
Jamie |
#10 |
Series or parallel
I would not use MWBC's unless I had to. Why do you want to use them in the kitchen? You can install all the required receptacles on two single branch circuits. Do you have a special need for the MWBC's?
#11 | |
DIY'er
Plus I need to tap off of the same runs of conduit for new wiring for 3 bathrooms and for my upstairs bar outlets. So I need as much space as I can get due to the wire limits due to derating factors that apply. Jamie |
#12 |
Series or parallel
If it where me i would hook them up in parallel
#13 |
Series or parallel
When you wire up receptacles using pigtails, you aren't subject to the resistance of the receptacle. This can lower your power bill by a fair margin if you do it on all your receptacles throughout the house.
I don't know exact numbers, but if you think about it the resistance across the ear of a receptacle is much lower than the wire you feed it with. So let's say for the sake of argument that the resistance of a receptacle ear is 2% higher than the resistance of your wire. After 10 receptacles, that resistance adds up to be 20% more than the branch circuit wire. The more resistance you have, the higher your power bill is. And also, I agree that a screw head installation can fail just as easily as a wire nut can if done improperly. |
#14 | |
It was a dark and stormy
#15 | |
I seriously doubt the resistance of a receptacle is measurably different than that of a wire nut splice. I mean, it may be measurable in a lab under controlled conditions. Which means it is so small as to be insignificant in practice. In fact, I might even venture that the resistance through a receptacle may actually be less than that of a wire nutted splice, because the terminal contacts the conductor on both sides, pretty much doubling the surface area compared to that available in a twisted splice, not counting the steel spring of the wire nut. |
| Display Modes | |
| parallel / series wiring question | geetee | Electrical | 5 | 06-11-2008 03:42 PM |
| Diagram of dual hot water heater (s) in parallel not series having flow questions-- | timlltt | Interior Decorating | 1 | 02-29-2008 04:01 AM |
| Wire Recepts. in Series or Parallel? | twilightcall | Electrical | 36 | 01-13-2008 04:13 PM |
| Parallel vs. Series Circuit | johnson217 | Electrical | 1 | 06-19-2005 11:03 PM |
