Serial Or Parallel? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 09:39 AM   #1
hohadcr's Avatar
Rewards Points: 306
serial or parallel?
Hi, I need some basic theoretical instruction here.
I have been puzzled:
1. are the two fuses that comes from the street and before the breaker box serial or parallel? Why?
2. are the breakers for 240V working on two 120V serial or parallel ? Why?
3. If we take one 240 line out of the breaker and add a fuse box before the appliance, the two fuses in this box are serial or parallel? Why?
Any background theories that i should learn about?
Thanks a lot.
hohadcr is offline   Reply With Quote
Old 11-18-2009, 10:18 AM   #2
Master Electrician
Grimlock's Avatar
Check out this site
http://www.allaboutcircuits.com/
Grimlock is offline   Reply With Quote
Old 11-18-2009, 10:23 AM   #3
Remodeling Contractor
serial or parallel have nothing to do with any of your questions. The two fuses are two separate out of phase 120V lines. Connecting a fuse box to an appliance would make no sense anyway. And again you are just adding an inline fuse to each of the separate 120V lines. This fuse is in series if you will.
Old 11-18-2009, 10:44 AM   #4
Rewards Points: 1,418
In each of these three situations (oversimplified to make the English sentences shorter), the elements or components described are in series.
In a really old fashioned or a miniature set of Christmas lights the current goes from one plug prong (through the wires) to one lamp and on to the next lamp and on to the next ... and back to the other plug prong. Should one light burn out, the others also go out (unless there is a special link inside the burned out lamp).
The typical current path for a 240 volt appliance is from one live wire out on the utility pole down to the fuse box (or breaker box), through one fuse (or breaker), then to the appliance, then back via the other live wire to its fuse (or breaker) and back out to the utility pole. The fuses must be in series with the appliance so that an overload will blow one or both fuses, breaking the circuit.
The typical current path for a 120 volt appliance is from one live wire out on the utility pole down to the fuse box, through one fuse, then to the appliance, then back via the neutral which goes dirctly back to the utility pole.
Now, parallel circuits.
Two or more household lights or appliances are always connected in parallel with each other, not in series. But together they are in series with the fuse. Current from the utility pole goes through a fuse, then has a choice of going through one appliance or the other appliance, then arriving at the neutral and going back to the utility pole. Considering just the portion of the circuit after the fuse, everything is in parallel. If the fuse blows, all the lights and appliances on that circuit go dead. If one light or appliance on the circuit is turned off, others stay on.
Connecting an appliance to its own fuse box.
(going into a little more detail) CUrrent comes from the utility pole down to the fuse box then goes through one main fuse (say 100 amp rating) then to a branch circuit fuse (say 20 amps rating) then to the appliance, then to neutral and back to the utility pole. The circuit described is a series circuit relative to the components mentioned. It is like having a separate fuse box for the appliance within the main fuse box.
Occasionally a smaller fuse box that is physically separated from the main fuse box is indeed found near an appliance such as a clothes dryer. This is classified as a subpanel.
Old 11-18-2009, 06:12 PM   #5
Rewards Points: 1,016
Fuses and circuit breakers are placed in series with the device they are protecting. Methinks your questions are misplaced for the concepts of parallel and series circuits.
Old 11-18-2009, 06:45 PM   #6
2. Any background theories that i should learn about?
1. Paralleling fuses requires some assurance that the current will be shared equally. This requires each fuse to have a known and controlled resistance, in addition to contact impedances being known and controlled.
If a 30A fuse has 1/30 ohm of resistance, and contact impedance accounts for, I don't know, 1 milliohm, and these values vary all over the place, you could make a 60A fuse by putting each fuse in series with a 0.2 ohm. 1kw [or larger] resistor, and put these two assemblies in parallel.
You may be able to make the resistors out of short pieces of skinny wire that don't melt at 30A.
This current-sharing design may have downsides, depending on your application. For me it worked, to ensure current sharing between two 10A relay contacts when I needed almost 20A.
2. No, just practical concerns. In theory, you could parallel fuses.
Old 11-21-2009, 11:28 AM   #7
hohadcr's Avatar
Rewards Points: 306
Thank you all very very much!
Parallel path to Ground - I'm confused as usual robertmee Electrical 13 04-03-2011 10:37 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Series or parallel runronno Electrical 29 07-17-2009 12:40 PM
basement framing, walls parallel to joists DIY4EVER Building & Construction 8 06-06-2007 04:08 PM
Parallel vs. Series Circuit johnson217 Electrical 1 06-19-2005 11:03 PM
