Ser Subject To Physical Damage - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 01:01 AM   #1
Rewards Points: 212
ser subject to physical damage
I am running 4/0, 4/0, 4/0, 2/0 ser. I am coming through the back of the service disconnect mounted on the exterior of my house and into a bedroom.
The cable will be running inside of a 2x4 wall covered with drywall.
Is the cable subject to physical damage? I sorta think that it is because someone could hang a picture on the bedroom wall with a long nail and drive a nail in it.
Well I helped a friend of mine do his last year in the same situation and we ran conduit from where the wire entered the wall up to the attic and the inspector made us remove the conduit. This is a different county, so different inspector. I just don't want to go to the trouble of putting the cable in conduit and the inspector make me remove it.
What do you think? Should I put it in conduit for the 5 feet that it is in the bedroom wall?
bluebird5 is offline   Reply With Quote
Old 10-05-2013, 07:51 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
There is no way you are going to be able to bend 4/0 SER in a 2x4 wall cavity, The bending radius cannot be more than 5x the diameter of the cable, with that said, no other violation. Other than your disconnect may not be deep enough to make the proper bend when entering from the back side.
Old 10-05-2013, 07:54 AM   #3
E2 Electrician
What code section did he site for removing the conduit?
Old 10-05-2013, 08:07 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you run that SE cable thru an insulated wall, you will be limited to 60 C which will only be rated for 150A.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (10-05-2013)
Old 10-05-2013, 08:29 AM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Conduid and an LB to get inside would be the easiest way and use 4 individual wires.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 10-05-2013, 09:07 AM   #6
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
The feeder conductors shall not be required to have an ampacity greater than their service entrance conductors.
wirenut1110 is offline   Reply With Quote
Old 10-05-2013, 09:48 AM   #7
Licensed electrician
Rewards Points: 1,054
Just another spot where the code appears to conflict with itself.
Old 10-05-2013, 10:26 AM   #8
k_buz's Avatar
The ser after the meter is still service entrance conductors.
Old 10-05-2013, 10:51 AM   #9
Rewards Points: 510
Feeder...lol
If it was just the meter, he'd be using SEU?
Old 10-05-2013, 10:55 AM   #10
k_buz's Avatar
You would be correct in that case.
Tree trunk damage mikereno1 Gardening Forum 18 05-24-2013 04:20 AM
Codemakers gone wild: protection from physical damage WillK Electrical 6 06-15-2011 03:29 AM
Roof Felt Damage wgg1848 Roofing/Siding 1 03-13-2010 03:31 PM
