Ser/seu Cable Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 09:05 PM   #1
ser/seu cable outside
Hi,
We are running wire from a main panel in our basement to a subpanel in an attached garage that will supply power to the garage and addition that we just built. if we are going to use SEC cable from the main box in an unfinished basement to the sub panel in the garage with a 20 foot trip outside along the wall of the house and garage (it's a really old house so no way to run the wires through the walls/ceilings of the house). our question is can you run the SEC cable outside just attached to the wall or does it have to go through conduit to meet code.
I don't want to spend the money and time and then fail the inspection. I could not find if it was allowed or not in the NEC book.
I really appreciate any help you can give us.
Thanks!!!!
Pollardmd is offline   Reply With Quote
Old 11-09-2012, 10:23 PM   #2
Master Electrician
Rewards Points: 3,678
What is SEC cable? You will need to use 4 conductor SER and yes, it may be installed exposed. Probably will look like heck but it is allowed under the NEC unless local ordinances say otherwise.
brric is offline   Reply With Quote
Old 11-10-2012, 06:34 PM   #3
Smile
Thanks, it was a typo! The cable will run behind bushes so it will be hard to see.
Thanks for the quick answer!!
sound out of cable box amakarevic Home Theater 11 05-18-2012 11:26 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 09:33 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
