SER Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 11:52 AM   #1
Question
SER Cable
I have added a large garage to my home. I currently have a 100 amp breaker panel and 100 amp meter base on the existing part, I have put a 200 amp meter combo on the far exterior (which is about 70') with a new 200 amp breaker panel back to back. I am putting a 100 amp breaker in the new 200 amp panel and running a service entrance cable from the existing 100 to the new 200 panel to this 100 amp breaker. My question is, what size service entry cable is needed to join these two panels that will supply the old 100 amp panel? Also, is aluminum safe or should I consider copper? All inside wiring is copper and this cable will be ran inside the garage. Some say if aluminum, it needs an inhibitor, some say that is only when connecting aluminum to copper, then I've read it can heat and be flamable. I am totally confused at this point.
oltl is offline   Reply With Quote
Old 03-12-2010, 12:04 PM   #2
Master Electrician
Rewards Points: 3,678
If I understand this correctly you are installing a new 200 amp service and abadoning the 100 amp meter and refeeding the the original 100 amp panel.
for 100 amp feeder back to 100 amp panel you will need 1/0-1/0-1/0-2 Al SER for 100 amps. Aluminum service cables are perfectly safe when installed properly. Antioxidants are not required by code but is an issue determined by the wire manufacturers. We always use it anyway just to be safe.
The refed 100 amp panel will need the equipment grounds and neutrals isolated as it will no longer be the service equipment.
brric is offline   Reply With Quote
Old 03-13-2010, 11:32 AM   #3
SER Cable-Thank you
Brric, thank you for your reply, this is very helpful. Just one more question, if I decide to go copper will a 2-2-2-3 or a 2-2-2-4 work for this? Codes don't really apply where I am, but I want to be safe. Thanks
Old 03-13-2010, 11:41 AM   #4
Codes apply EVERYWHERE
Its called the National Electric Code
Old 03-13-2010, 11:45 AM   #5
Master Electrician
1-1-1-3 Cu SER would be code compliant.
Old 03-13-2010, 11:47 AM   #6
Master Electrician
Codes never apply unless they are adopted and enforced by the various AHJ's.
Old 03-13-2010, 11:55 AM   #7
Can you name an area in the US that does not have an electric code ?
Code still applies even if it is not enforced
Its the Min standard to go by
Old 03-13-2010, 12:21 PM   #8
SER Cable
Again, thanks brric. Scubba_Dave, I only meant not any particular city code. Didn't mean to offend anyone. I totally understand what you are saying, and I do respect the "National" codes. New at this, and how things can be misunderstood, next time I will be more careful with how I word things. First time to ask a question on line, so please forgive me. God Bless You and thank you for your reply also.
Old 03-13-2010, 01:59 PM   #9
Electrical Contractor
kbsparky's Avatar
If you use THHN/THWN copper conductors in a conduit, then all you would need is #3-3-4-8 for the 100 Amp feeder back to your original panel.
-KB
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
