Septic Tank Uphill Pump Systems - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 09:28 PM   #1
septic tank uphill pump systems
I have a septic system that pumps uphill.The pump has stopped working.It has its own panel box in the the basement.There are 2 sets of breakers and 2 sets of 1 amp glass auto like fuses .1 set is marked control and the other set is marked alarm.The control side is blowing the glass fuse.
At first I thought it was the pump or the outlit in the tank that up plug the pump into. I have unpluged the pump and have disconnected the outlit and it still trips.
Thanks for your help
keith6671 is offline   Reply With Quote
Old 12-28-2011, 10:22 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,608
The CONTROL fuse does not power the pump diectily !
Instead it provides power for bildge switchs and the like,
and these switchs operate relays/contactors,
and it is these relays that directily operate the pumps.
You have clearly got problems with your control gear
side of things, so this is where you should look !
Not looking at the pumps.
Without knowing more about your specific set up
I cannot say exactily where your issue is,
But start at the sump tank,
and check the switchs and wiring.
dmxtothemax is offline   Reply With Quote
Old 12-28-2011, 10:44 PM   #3
MarginallyQualified
Rewards Points: 2,464
Or... maybe not.
Maybe that control circuit is doing exactly what it is supposed to.
But start at the sump tank,and check the switchs and wiring.
This I agree with 100%.
Start with a schematic to go by and a good VOM.
To be clear, I've never worked on one of these but hearsay tells me
they are notorious for needing the pump replaced fairly often.
hth
Old 01-02-2012, 08:34 PM   #4
Scottphys's Avatar
Have you checked your splice box for shorts or leaking?
Scottphys is offline   Reply With Quote
Old 01-03-2012, 06:04 PM   #5
hth
Considering the enviroment in which the have to work in !
That is completily understandable !
Not only do the pumps suffer !
But everything else does to !
Switchs,wiring,mountings.
Corrosion is usually a big problem due to the acidic nature
of human waste and urine !
Good Pump For Septic - 70 horizontal feet JohnSlider Plumbing 2 01-03-2012 08:20 PM
Help with ejector pump biggidybankston Plumbing 3 10-18-2011 01:36 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Adding a roof over deck/patio, close to septic tank ncpaladin Building & Construction 0 02-21-2010 12:15 PM
My Septic drainfield must be filled with roots, what do I do? BJLower Plumbing 1 04-25-2009 01:22 PM
