Septic System Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 10:40 AM   #1
I just had a sand mound septic system installed and need to complete the wiring. I have a 1 HP pump and a float alarm. The problem is the distance I have to go. The dosing tank is about 450' from the house and power source. I decided to put a sub panel at the dosing tank and was told that I needed to use 2-2-2-4 Aluminum SER wire. The wire will be in buried underground in PVC conduit for about 400'. The sub panel will only have two circuits, a 20A / 240v pump circuit and a 20A / 120V GFI outlet. The alarm wire will also be in the same conduit but was specified as 14-2. The questions are:
Is the 2-2-2-4 SER wire suitable for use in underground conduit?
Can 14-2 NM wire be used in the same conduit or is there another type THHN or THWN that would be better?
An electrician will make the final connections but I will be supplying the wire, conduit and materials.
Chris843 is offline   Reply With Quote
Old 10-03-2013, 10:45 AM   #2
Rewards Points: 246
Don't they make a panel just for this job? With receptacle included? If so, use one of them.
On your VD. Google the words (voltage drop calculator) and use it to determine your VD and wire size.
I am not familiar with your system, but I am familiar with motor and control.
Do you have a drawing to work from? Are you designing this as well as installing this system?
Old 10-03-2013, 10:54 AM   #3
I could not find a panel exactly like I wanted but got a 4 circuit outdoor panel and installed a 20Amp GFI on the back of the post that it is mounted to. I used a voltage drop calculator and it came up with #2 wire for 20 amps at the end of the line with less than a 3% drop. I need 12 amps for the pump and wanted a little more for the outlet.
This system was part of a design for the sand mound but the designer did not have an electrical background and just specified the equipment needed.
Thanks.
Old 10-03-2013, 06:01 PM   #4
Licensed electrician
Rewards Points: 1,884
SER cannot be buried.
Types NM cable cannot be used outside.
Old 10-03-2013, 06:16 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by Chris843 View Post
An electrician will make "the final connections" but I will be supplying the wire, conduit and materials.
May I ask why? Why not let the right person do the whole job?
"The final connections" is by far the easy part. What you are doing is what takes code and technical knowledge.
Also, what genius designed such a system??? 450' from power source to pump??
Makes no sense to me at all.
Old 10-03-2013, 06:46 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I would see if the POCO could drop another pole closer.
jbfan is online now   Reply With Quote
Old 10-03-2013, 09:27 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
So your turds are going to travel 450', then need a pump? okay.....
Old 10-03-2013, 09:46 PM   #8
joed's Avatar
Rewards Points: 13,740
Agree, that sound weird. Should be a shorter flow and then pump it 450 feet.
Old 10-03-2013, 09:49 PM   #9
E2 Electrician
Yep, most septic pump jobs I do are around 50' - 100' from the structure...
Old 10-03-2013, 11:59 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,608
You should ask the electrician who is going to do the final connection what he would like you to use !
If he does the final connection, then he is responsible for the safety of the system.
And so a lot of electricians are uncomfortable in taking responsibility
for other peoples work or work they did not do themselves.
dmxtothemax is offline   Reply With Quote
Old 10-04-2013, 05:27 AM   #11
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Unless the house is on a mountain and your tank is at the bottom of the mountain, the drain line would have to be over 112' in the ground @ 1/4" drop per foot.
wirenut1110 is offline   Reply With Quote
Old 10-04-2013, 06:48 AM   #12
Rewards Points: 510
I guess I don't know what a sand mound septic system is
Old 10-04-2013, 07:47 AM   #13
joed's Avatar
A sand mound system is used where there is not enough soil depth for a leach field. Usually rocky areas with only a few feet of soil over the rocks. The hill of sandy soil is built in the yard and the effluent from the septic tank is pumped up into the leach field installed in this hill.
The Following 3 Users Say Thank You to joed For This Useful Post:
J. V. (10-04-2013), stickboy1375 (10-04-2013), wirenut1110 (10-04-2013)
question about septic pump & alarm wiring. ACR_SCOUT Plumbing 8 02-04-2012 04:19 PM
Septic System Trouble vivaciousbee Plumbing 3 08-25-2011 02:33 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
