Separating Ground/neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 11:35 AM   #1
separating ground/neutral
Got a general question on this.
My home was built in the early 1980s and has a 200A service, GOULD panel.
I've read and been told that
1- There must be a separate ground and neutral
2- then, in following hte above, all the ground connections should be on one side bar
2b. all the Neutral on the other side bar
Did the code changed in this aspect?
My house was done by a licensed electrician and inspected etc.
Is this really all wrong?
OR did the code change?
If the code changed, does this mean now that ANY changes made
have to bring this all up to code?
(in which case, I'm moving
tmorriss is offline   Reply With Quote
Old 03-10-2011, 11:54 AM   #2
Licensed electrician
Rewards Points: 1,884
If this is in your service panel the neutrals and grounds can be on eh same buss. If there is a means of disconnect outside between the meter and this panel the neutrals and grounds should be separated. In this case you would have 4 wires coming into the panel.
3 main structural beams separating. What should I do? Doug17 Building & Construction 13 01-03-2011 07:33 PM
Brick separating from the block Kxlara General DIY Discussions 3 01-03-2011 10:26 AM
separating a fan and light. Knightwing72 Electrical 4 09-16-2010 11:12 AM
Fascia separating from eaves Sooz Building & Construction 4 08-26-2010 09:10 PM
Tub, Separating valve and spout bigmatt Plumbing 0 02-05-2010 03:23 PM
