Separate Plug On Electrical Pane - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 12:56 PM   #1
separate plug on electrical pane
Why is there a single electric plug hooked up to the panel directly (own circuit) in new home construction?
fdasilva is offline   Reply With Quote
Old 06-08-2011, 01:18 PM   #2
Rewards Points: 6,652
Really need a picture to see what you are talking about.
Old 06-08-2011, 01:25 PM   #3
Let me clarify.
I just bought a house and besides all the reqular wiring and circuits in the panel there is a sole electrical plug with its own circuit breaker located right beside the panel. What is the reasoning for this? I'm sure the builder wouldn't add a separate breaker if not required.
Old 06-08-2011, 01:49 PM   #4
Originally Posted by fdasilva View Post
Let me clarify.
Let me clarify your question. Need a picture of what you are talking about. Really can not tell you about your set up, unless A) You talk to the electrician that wired the house, or b) post a picture showing this set up, and if possible, you may have to open the panel up and trace the wire to see where they go to see which breaker they attach to.
I put an outlet on my panel for use for my home network equipment, and to have a convenience outlet there, when I had my workbench in that spot. Everyone's set up is different, not all are going to be the same purpose or reason why there is an outlet on the panel.
Old 06-08-2011, 02:23 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
If the panel is in the basement, that covers the required receptacle for the basement.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
frenchelectrican (06-09-2011), Speedy Petey (06-08-2011)
Old 06-08-2011, 02:27 PM   #6
Master Electrician
Rewards Points: 3,918
And it is probably used for construction power.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
Old 06-08-2011, 02:30 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Don't be so sure.
See post's 5 & 6.
Old 06-08-2011, 03:06 PM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Some Poco's require atleast one receptacle outlet in order to turn the service on. Could also be for temp construction power, or could be the required basement receptacle outlet. Regardless, it needs to be GFI protected.
Also, it is not a "plug" it is a receptacle outlet.
electures is offline   Reply With Quote
Old 06-08-2011, 03:08 PM   #9
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
The basement does need a plug so yes it would cover that. It is a common misconception that a "Panel Plug" is code when in fact there is no such code. But it is code for the basement to have at least one plug and the most convenient cheapest place for the plug is right next to the panel.
Big N8 is offline   Reply With Quote
Old 06-08-2011, 03:35 PM   #10
Learning by Doing
Leah Frances's Avatar
It may not be code but it's really, really handy. One if the first things I ever did was add one!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-09-2011, 12:15 AM   #11
Rewards Points: 512
Okay, (took me a moment, but) so you're saying that there's nor requirement for a receptacle to be located on or near the panel. OK! But, I've never heard that this was a "common misconception".
Old 06-09-2011, 12:55 AM   #12
Learning by Doing
Sparks: you must not be a common misconceiver.
Old 06-09-2011, 01:15 AM   #13
Rewards Points: 512
LOL, I was actually misconceiving when I first read the post
Old 06-09-2011, 01:41 AM   #14
" Euro " electrician
frenchelectrican's Avatar
Majorty of the time with new panels I will installed RCD'ed protected recetpale next to the breaker box that is pretty much SOP for many new home consturuction as post #5 et #6 did mention clear on that.
And when I upgrade the service I do the same thing as well.
Merci,
Marc
Old 06-09-2011, 09:13 AM   #15
It is funny how the SOP is, and what I thought I was doing, was just for my convenience, since I looked at having the outlet by the stairs for the upright freezer as the "one" outlet needed in the basement, under the requirement. I just looked at the spot underneath the stairs as the best place to put the networking equipment, and the modem/router for my ISP provider, with the outlet on the panel, since they sit next to each other.
Now, if it would only be standard SOP to have whole house surge protectors on the panels. Mine has saved my butt plenty of times as first level of protection.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
how to find an electrical plug, covered up by a wall luckymen Electrical 15 07-07-2009 06:27 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
Glasshouse heater plug melting stuie Electrical 7 04-21-2009 10:54 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
