Separate Main Panels? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 01:49 PM   #1
just a dude
Rewards Points: 34
Hi,
I have hired a contractor to put an addition on our home. It will consist of a basement and two stories above that. Because it doubles the size of our home, we are upgrading the electric from 200 amp to 400 amp (I will be running a little extra to my woodshop as well).
Anyway, the contractor intends to create a separate 200 amp main panel in the addition's basement rather than upgrade our current panel. Does this sound like an acceptable option? I am having some doubts. That would leave our current 200 amp panel in the garage of the existing home and the new one three rooms and a flight of stairs away.
He intends to run the woodshop sub panel from the new panel in the addition, since it will be much closer. I live in Ohio if that means anything.
Thoughts?
Thanks,
Rob
rocklobster is offline   Reply With Quote
Old 12-16-2012, 03:16 PM   #2
Master Electrician
Rewards Points: 3,870
Sounds to me like the contractor has a viable plan. You are not in a good place if you are questioning his judgement from the start.
brric is online now   Reply With Quote
Old 12-16-2012, 03:16 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Sounds fine. The main for the 200A subpanel will have to located next to the main for the existing service. The service entrance conductors to each main will have to be sized for the calculated load.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
NJMarine (12-16-2012)
Old 12-16-2012, 03:44 PM   #4
just a dude
Rewards Points: 34
There was no mention of a main for a 200A subpanel being next to the existing service, which is what concerned me. I want to be able to shut off everything from one location.
I'll double check with him about that. It's possible that I merely overlooked it.
Thanks everyone.
Rob
Old 12-16-2012, 04:01 PM   #5
electures's Avatar
Thanks everyone.
Rob
The mains are required to be grouped together. There has to be a main.
Old 12-16-2012, 04:28 PM   #6
TTW
TTW's Avatar
You could put in a meter base with a main breaker. Then you can kill everything from the meter base.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-17-2012, 09:24 PM   #7
Rewards Points: 240
Yeah, something doesn't sound right... you can't put a main panel that far away from the service entrance, because it leaves a long run to the panel that has no overcurrent protection. You can put in a disconnect at/near the meter, but now that panel isn't a main; it's a subpanel. Are they going to take a 200A feed off of your existing panel? And if so, is it rated for 400A? Conversely, if a disconnect is being put in at the meter, that makes your existing panel a subpanel -- are they going to separate the grounds there?
fa_f3_20 is offline   Reply With Quote
Old 12-17-2012, 09:36 PM   #8
Master Electrician
You can if the service conductors are outside the structure or underneath below concrete.
The Following User Says Thank You to brric For This Useful Post:
TTW (12-17-2012)
Old 12-18-2012, 08:44 AM   #9
Licensed electrician
Rewards Points: 1,610
You could add a 200 amp sub from a 200 amp service without the service needing to be 400 amps. It all depends on the calculations.
Old 12-18-2012, 09:15 AM   #10
Missouri Bound's Avatar
Are you absolutely sure he's not just adding a sub panel?
Do you want it your way or the right way?
Can I use a breaker on the buss as the panel main? dirtynails Electrical 11 11-19-2012 07:32 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 08:43 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Wire for main panels scrayzee21 Electrical 3 10-18-2008 12:35 PM
