Old 03-03-2011, 01:07 PM   #1
Separate Kitchen sub-panel or not?
My 200 AMP main panel is starting to get a little crowded. I have enough circuits for my new kitchen renovation, but does it make any sense to install a separate sub-panel dedicated just to kitchen circuits? If so, how big? 100AMP? It makes sense to me, in that I would save circuits on the main panel for future electrical expansions, and have all the kitchen stuff organized in one easy box, with a separate main cut-off, if need be. Is this common at all? Thanks
tpagel is offline   Reply With Quote
Old 03-03-2011, 01:13 PM   #2
Nothing wrong with adding the sub panel but I wouldn't worry too much about having it dedicated just to the kitchen. I would install one when I ran out of room in the main panel when needed. What size main panel do you have? If you don't have the largest panel for a main panel then you could always upgrade that to a bigger panel.
teamo is offline   Reply With Quote
Old 03-03-2011, 01:27 PM   #3
My main panel is 200 AMP. I think it has maybe 8-10 spaces or so left on it. It is actually in the attic (yeah...weird), on the opposite end of the house from the kitchen. I created an electrical room around it, for when I finish off the attic. My plan was to install a sub-panel directly above the kitchen, so I could run only one homerun to the main panel, and all the kitchen wiring basically straight up and into a small dedicated box. Seems the most efficient, especially since the area above the kitchen would still be a storage area, even when the attic is finished out. Would a 60 AMP panel be enough for kitchen wiring?
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
Circuit Breaker Panel Height? helpless handyman Electrical 19 05-04-2008 10:06 AM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
