Separate Ground Rod For Antenna? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 06:43 PM   #1
Rewards Points: 874
Separate ground rod for antenna?
Hi;
I am going to install an antenna outside the attic window for my 2 meter ham riig. I will be using it to transmit, so I just want to make sure the rules don't change from those which apply to a receiving antenna.
Can I still use the same ground rod that the electric SE is using by splicing into the ground wire with a clamp-on type of connector (I am not going to cut the grounding wire).
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-06-2009, 06:53 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by KE2KB View Post
Hi;
FW
Hello;
This is the correct procedure per my understanding. You just use a regular clamp rated for the size of wire your using for grounding your ham setup. If you install a second rod for the Ham, you need to bond that rod via 6awg cable to the rest of your rods (or I believe it can also be connected directly to your SE)Here is a link to some info Holt wrote on the subject:
http://www.mikeholt.com/technical.ph...ish%20(1-12-2K)
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-06-2009, 10:46 PM   #3
Rewards Points: 1,016
Ham site suggested
I would suggest you do a search on one of several ham radio sites - huge amounts of information there regarding antennas, radio equipment, and grounding system installation.
A couple of my favorites -
www.eham.com
www.qrz.com
73's
Vince
W6CD
Old 03-07-2009, 08:05 AM   #4
Rewards Points: 874
Thanks guys;
Sorry for my ignorance. Not only do I have bookmarks of several ham forums, but I have a copy, albeit an electronic copy of the NEC 2005 and also 2008.
FW
Old 03-07-2009, 10:10 AM   #5
Rewards Points: 126
Same bonding rule applies. Bonding conductor must be attached to the grounding electrode system of the main service. A split bolt works good for this.
Old 03-09-2009, 03:28 PM   #6
Rewards Points: 874
Thanks.
Now I've got to find out whether or not I can even install the antenna. I can't get the top half of my attic window open, and will need to do so in order to secure the upper support.
I may end up just sticking it through the vent in the attic roof<g>
FW
Old 03-10-2009, 11:37 AM   #7
Rewards Points: 126
Thanks.
FW
Sounds like the bonding was the easy part. Good luck on the mast install.
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 10:14 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
