Separate Circuit For Recording Studio - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 12:19 PM   #1
separate circuit for recording studio
i want to add a circuit for my home recording studio because it seems like all my electronics are drawing to much power from the existing outlets what would i need to do this? or how?
aos87 is offline   Reply With Quote
Old 09-17-2012, 12:22 PM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Too many answers to give. Please be more specific.
Big N8 is offline   Reply With Quote
Old 09-17-2012, 12:38 PM   #3
basically i want to add maybe 3 outlets that can handle the load of all the amplifiers mixing board pa system effect pedals and such.
Old 09-17-2012, 01:28 PM   #4
Licensed electrician
Rewards Points: 1,880
The short answer is to run a new cable back to the panel. Too many variables would enter the picture as to how to do that.
Old 09-17-2012, 07:15 PM   #5
Rewards Points: 6,652
Are you tripping breakers as it is set up right now?
Old 09-17-2012, 07:16 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
How much power do you need ?
The power amps will probably be the biggest drawer,
How many amps ?
How much power do the amps put out ?
You will have to run a new circuit back to your panel,
one or two depends on your loads.
As for exacilty how ?
We would need more details on your building layout.
dmxtothemax is offline   Reply With Quote
Old 09-17-2012, 07:18 PM   #7
The amps would be his biggest draw dmx. The board or desk would be the next. Really need list of equipment and power ratings off of the plates, along with amp of the circuits that they have all of this plugged into.
With today's computers, you do not even need amps for recording, since everything would mix through the computer. Even then, you would only need a max of 2 20 amp circuits for everything.
Old 09-17-2012, 07:30 PM   #8
liscenced electrician
Rewards Points: 538
Way too vague of a question but to be overkill I'd run a 12/3 back to your panel and run a multiwire branch circuit. I'm guessing you'd have all the power you need
jimmy21 is offline   Reply With Quote
Circuit for bathroom in the basement felipe_heidrich Electrical 4 08-26-2011 04:54 PM
4 way circuit to a 3 way circuit BigAtl Electrical 8 12-16-2010 01:59 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
