Separate Breaker For Floor Heat? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 09:30 AM   #1
Just call me Andrew
Rewards Points: 1,020
Separate breaker for floor heat?
I am about to begin remodeling my bathroom. I will be installing a 15 sq. foot SunTouch floor warming mat/thermostat. According to the documentation, a 15 sq. foot mat draws only 1.5 Amps. I will be running a new 20A circuit to feed lighting and outlets in this bathroom only. Can this circuit also feed my floor warmer? Should I run a separate circuit for it?
If I decide on (or am required to run) a dedicated circuit, do they make breakers smaller than 15Amps? It seems safer to run even a 5- or 10-amp breaker if they so existed, that way if the mat shorted out it would be even less flow to cause a trip.
Ideas?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-08-2010, 09:47 AM   #2
Master Electrician
Rewards Points: 3,680
IMO it would be better to run a dedicated 20 amp circuit to the bathroom recep and a 15 amp circuit for the lighting and floor heat. We always use dedicated 20 amp recep circuits for bathrooms. The floor heat I am familiar with has an integral GFIC with the thermostat. The mat circuit should be GFCI protected.
brric is offline   Reply With Quote
Old 04-08-2010, 10:26 AM   #3
Just call me Andrew
Yes, the thermostat has a built-in GFCI. Not a bad idea to do the lighting and the mat on one 15a circuit, outlet on a dedicated 20a. I'll do that.
Is this lighting/heat circuit (no outlets) allowed to be shared with another bathroom in the future? I know the rule regarding outlets (one bathrom outlets+lights, multiple bathrooms outlets only).
Andrew
Old 04-08-2010, 10:42 AM   #4
Yeah, I'd keep it seperate, my lights are always on another circuit
Yes the lights & heat can be shared with another bathroom or any other room
Bathroom requires a dedicated 20a circuit that feeds all lights & outlets in that bathroom
OR
Can feed outlets only in multiple bathrooms
So as long as you have the 20a, anything else is above code
Old 04-09-2010, 10:29 AM   #5
Just call me Andrew
These runs will be perpendicular to joists. Do I need to install running boards if they are over a dropped ceiling?
Andrew
Old 04-09-2010, 10:37 AM   #6
Master Electrician
No they do not. They are considerd protected in that case.
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Checking a Breaker Klawman Electrical 11 02-18-2010 08:48 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
