Self-Feed Bits - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 08:06 AM   #1
jburd964's Avatar
Rewards Points: 166
Self-Feed Bits
Needing to purchase a Self-Feed Bit are Bits for home electrical rough in, any favorites are recommendations?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 01-17-2013, 08:25 PM   #2
Licensed electrician
Rewards Points: 1,290
I like these.
http://www.lenoxtools.com/pages/Prod...etalUtilityBit
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
electures (01-18-2013), jburd964 (01-17-2013)
Old 01-17-2013, 10:42 PM   #3
eastcoastsparky's Avatar
Rewards Points: 150
Greelee nail biter auger bits. They go thru anything
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
Old 01-17-2013, 10:47 PM   #4
Rewards Points: 13,300
A simple cheap paddle bit will do the same job a whole lot cheaper.
Old 01-18-2013, 12:54 AM   #5
" Euro " electrician
frenchelectrican's Avatar
As long you don't hit any nail the cheap paddle bits will work but normally I like to use the augar bits they last super long time and I have nail eater verison which it actually shear off the nails when I bore thru the stud or beams.
Just make sure you bore in the centre of the stud that will work the best.
Majorty of the time the 3/4 or 7/8 inch bit will serve the purpose most of the time but there are couple spots you will have to get larger bit to drill thru for larger cables or conduits.
Merci,
Marc
Old 01-18-2013, 07:49 AM   #6
Rewards Points: 3,130
Another vote for Greenlee.
The Following User Says Thank You to md2lgyk For This Useful Post:
Tags
drill bit , electrical rough-in , tools
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 06:40 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Why can't I find straight concrete drill bits? DawsonMobley Tools 13 12-13-2010 01:31 PM
Auger bits last longer than spade bits? Ultrarunner2017 Electrical 36 01-31-2009 12:10 PM
best bit(s) to do electircal install rtoni Electrical 13 11-26-2007 09:24 AM
