Securing Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 05:21 AM   #1
Securing Romex
Question about securing Romex when running parallel to a stud, I think I know the right answer but want to make sure.....as long as you are stapling to the stud you do not have to meet the 1 1/4" from the edge correct? The 1 1/4 from the edge only comes into play when you are drilling directly through the stud and running perpendicular right? Thanks for the help.
steve37887 is offline   Reply With Quote
Old 02-23-2009, 05:53 AM   #2
Remodeling Contractor
correct, but stapling tight to the front edge will still offer the chance to drive a nail into the wire. You should try to staple the wire to the center of the joists.
Old 02-23-2009, 06:10 AM   #3
Electrical Contractor
300.4(D) states that the cable shall be kept 1 1/4" from the edge of the framing member when running parallel.
hpp58 is offline   Reply With Quote
Old 02-23-2009, 08:23 AM   #4
Registered User
Termite's Avatar
Yes it does, and it goes on to say that protection plates should be used when the wire is closer than 1-1/4" to the face of the stud or joist.
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Running Romex Bocolo Electrical 6 02-20-2009 09:58 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
Romex to BX fifaboy Electrical 1 02-27-2005 04:12 PM
