Securing Outlet Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 05:44 AM   #1
Rewards Points: 150
Hi all,
Just a quick question, I am looking on advice on how to secure the wires into, and out of my outlet boxes (I think code is that they must be secured within 12" of enter/exit of the gang box). I think this is traditionally done with the staples but I have superior walls in my basement and I'm not sure what would be the best way to secure these wires being that the studs are foam wrapped.
I'm sure you all are familiar with superior walls but I attached a picture just in case.
stradt03 is offline   Reply With Quote
Old 07-16-2011, 05:52 AM   #2
Rewards Points: 1,534
Use long screws that will penetrate the foam and get into the studs. You can get a collar that encircles the wire and that has a tab with hole for one screw to hold it onto the stud.
How are you going to anchor the outlet boxes?
Old 07-16-2011, 06:41 AM   #3
Rewards Points: 150
self tapping screws into the galvanized steel lip.
Old 07-16-2011, 06:45 AM   #4
Lic Elect/Inspector/CPO
You will need romex or pushin connector to secure wire or wires to the boxes.
NJMarine is offline   Reply With Quote
Old 07-16-2011, 06:51 AM   #5
deleted.
Old 07-16-2011, 07:10 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Totally agree. They way you have it is non-compliant and not safe.
As far as securing goes, use TapCons, or other concrete screws, to fasten tie-wraps with a mounting lug.
Old 07-16-2011, 04:11 PM   #7
Rewards Points: 150
Could you post a pic of these or link me to them? I'm not sure I know what these are. Thanks for letting me know I was in violation of code.
Jason
Old 07-16-2011, 04:15 PM   #8
electrician
Look up NM connector on google. The ones I often see are black plastic around here.
here is a link to amazon:
http://www.amazon.com/Gam-Pak-Produc.../dp/B000TTFA3O
tweak is offline   Reply With Quote
Old 07-16-2011, 04:28 PM   #9
These are exactly what you should use. Only thing is, the link is for 3/4". You need 1/2".
The Following User Says Thank You to Speedy Petey For This Useful Post:
tweak (07-16-2011)
Old 07-16-2011, 04:31 PM   #10
Licensed electrician
Rewards Points: 1,750
To make it easier to comply with fastening the cable within the 12" I would use the top or bottom knockouts, not the side one like shown.
220, two wire, hard wire, to 4 prong outlet jasesselstyn Electrical 9 11-27-2010 08:59 PM
"Split" wire in junction box to outlet and light froddan Electrical 6 12-07-2009 11:32 AM
Switching an outlet with Thermostat wire rocketdoctor Electrical 7 08-03-2009 01:39 PM
Switch Box / Outlet Photos (with mid wire skining) jamiedolan Electrical 22 02-18-2009 06:39 PM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 09:04 PM
