Securing MC/AC Cable To Existing Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 11:45 PM   #1
Rewards Points: 278
Securing MC/AC cable to existing outlet box
Standard 4" Steel Box in Wall.
I suppose a good wack of a flathead screw will be able to get a knockout out.
I plan to run a new line to this box if doable...
Do they make special fittings that I can use to secure a BX cable in a 1/2 knockout or 3/4 ........that I can secure to the box IF I only have access to the *inside* of the box ?
mobiledynamics is offline   Reply With Quote
Old 03-30-2012, 11:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Put the connector on before fishing it down the wall.
Otherwise, they make snap in connectors for MC that don't use a locknut.
Old 03-30-2012, 11:55 PM   #3
Rewards Points: 506
Put a connector onto the flex before you fish it to the box. Then have the nut handy to screw onto the connector. ???
jlmran is offline   Reply With Quote
Old 03-31-2012, 12:00 AM   #4
Rewards Points: 278
Genius - on putting the connector on the cable before fishing it ! I did not even think about doing it this way...
Old 03-31-2012, 12:08 AM   #5
Rewards Points: 506
This forum has an echo...
Old 03-31-2012, 09:16 PM   #6
Rewards Points: 278
Any secret sauce advice on knocking out the knockout from the inside of the box.
It's a tile backsplash so I want to keep vibration to a minimum...
Old 03-31-2012, 09:37 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Flat head screwdriver.
Push on tab to bend it,once it bends rock it back and forth till it snaps off.
sublime2 is offline   Reply With Quote
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Securing Cable Runs Over Block jkoll42 Electrical 2 03-15-2011 06:59 PM
install outlet through existing tile? hoosadam Electrical 3 02-01-2011 01:47 PM
Can i do this? tapping an existing outlet... nuf2BeDangerous Electrical 7 10-29-2009 06:10 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-19-2008 12:03 AM
