-   -   Securing MC/AC cable to existing outlet box (http://www.diychatroom.com/f18/securing-mc-ac-cable-existing-outlet-box-138787/)
mobiledynamics 03-30-2012 11:45 PM
Standard 4" Steel Box in Wall.
I suppose a good wack of a flathead screw will be able to get a knockout out.
I plan to run a new line to this box if doable...
Do they make special fittings that I can use to secure a BX cable in a 1/2 knockout or 3/4 ........that I can secure to the box IF I only have access to the *inside* of the box ?
k_buz 03-30-2012 11:52 PM
Put the connector on before fishing it down the wall.
Otherwise, they make snap in connectors for MC that don't use a locknut.
jlmran 03-30-2012 11:55 PM
Put a connector onto the flex before you fish it to the box. Then have the nut handy to screw onto the connector. ???
mobiledynamics 03-31-2012 12:00 AM
Genius - on putting the connector on the cable before fishing it ! I did not even think about doing it this way...
jlmran 03-31-2012 12:08 AM
This forum has an echo...
mobiledynamics 03-31-2012 09:16 PM
Any secret sauce advice on knocking out the knockout from the inside of the box.
It's a tile backsplash so I want to keep vibration to a minimum...
sublime2 03-31-2012 09:37 PM
Flat head screwdriver.
Push on tab to bend it,once it bends rock it back and forth till it snaps off.
