Securing Electrical Box In Block Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2009, 10:22 AM   #1
Question
securing electrical box in block wall
Hi everyone, I'm trying to figure out how to secure existing and new electrical boxes in a slump block wall (slump blocks have the hole in the center of the block and things tend to fall in). Some of the existing holes are to big and I also want add additional boxes to the house. what should i use to secure them in place. thnx
Harrington11 is offline   Reply With Quote
Old 03-26-2009, 11:00 AM   #2
Rewards Points: 204
For branch circuit boxes (receptacles and switches) push newspaper down in the hole and fill with mortar mix and push box in allowing it to squeeze out the sides. Clean up (smooth) excess with wet cloth or rag.
For panels it is a little harder. On new ones you can frame the opening with lumber and use screws to mount the panel from the sides. Or mount it on the surface with concrete anchors.
On existing panels wooden wedges may work. Maybe a combination of wedges and mortar mix. I'm certain the others will have some additional ideas.
Glueing Drywall to a Garage Block Wall PaliBob Drywall & Plaster 17 02-18-2009 05:12 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Taking down a conc block wall Oilerz Remodeling 1 01-05-2008 10:23 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 06:26 PM
