Securing Cables And Boxes...code? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 05:41 PM   #1
Rewards Points: 97
securing cables and boxes...code?
i have read several articles about securing ROMEX cables (12-2 or 14-2) and boxes. clarification of the following points will be appreciated.
1. cables
a. cable needs to be secured every 4'. if the cable is behind the sheetrock or a molding (which forms a raceway), does it still have to be stapled every 4'. if yes, i will hve to rip the sheetrock or the molding.
b. the cable has to be secured withing 12" of a box. if the box has a clamp at the entry point, is the securing still required?
2. Device box. Securing a device-box on a solid conduit (see diagram)...can a light box be supported solely on a solid conduit? i have to drop my outdoor flood about 8" and the simplest way i see is to attache the box at the end of the conduit. the cable is long enough so the splice-nuts will be in the light box.
thanks
add: the device here is an outdoor, plastic light fixture box.
drgkjd is offline   Reply With Quote
Old 05-30-2010, 06:34 PM   #2
1a) If the wire is being fished down the walls, ie during a remodel, and this is not new installation, than no you do not have to support it every 4'
1b) yes it must still be secured though you can use the cable clamp to do so.
2) it's ok under a few conditions, the light must be above 8', pipe can't be longer than 1', can't weigh over 20lbs, must use threaded metallic conduit.
fpeftw is offline   Reply With Quote
Old 05-30-2010, 09:25 PM   #3
Rewards Points: 97
thanks for your speedy reply. looks like i will have to do some destruction/construction for 1b but i meet all the conditions the flood...that make sit easy.
Orthodox Sub-Panel HooKooDooKu Electrical 19 03-02-2010 02:35 AM
Code compliance question: plug-in UPS inline with circuit ScottR Electrical 20 06-03-2009 05:26 PM
Installing 20 amp circuits in metal boxes, is 14 ga OK for ground pigtails? thegonagle Electrical 17 11-14-2008 08:34 AM
NEC code on rewiring? diverdaveman Electrical 15 07-11-2007 06:42 PM
