Secondary Surge Breaker Worth It? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 07:06 PM   #1
Trucon01's Avatar
Rewards Points: 510
Secondary Surge breaker worth it?
Hi All,
Are the secondary surge breakers really worth getting? The Square D QO surge breaker is 57 bucks at HD. Get it or save the money?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Trucon01 is offline   Reply With Quote
Old 01-18-2012, 08:07 PM   #2
Rewards Points: 6,652
The choice is yours. Those are Primary surge protection, secondary would be a surge strip that your stuff is plugged into the wall outlet. I have one of the intermatic's on my panel. It is the best insurance out there, along with using surge strips on your appliances with electronics, and electronics.
Old 01-18-2012, 10:02 PM   #3
I don't know why they call that a "Secondary Surge Arrester"?
I would call it a "Whole House Surge Arrester".
In either case, the more, the merrier I say!
Also there are 240 volt appliances like range/dryer and others which can not be placed on a surge protector power strip. Yet these have electronic controls in them these days. So well worth it to protect those as well.
Also good to have good quality (big $$ warranty) surge protectors on 120 volt electronic gizmos in addition to the above.
Billy_Bob is offline   Reply With Quote
Old 01-19-2012, 08:10 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
Concure with both.
One of the issues with your run of the mill power strip is that it most likely uses what is called MOV. When the voltage gets high enough (surge), if fires and shorts the ckt....typically triping the breaker...which is good....it protected the equipement downline....BUT, in most cases, once that MOV has fired....it's fried.....so the next surge will go unprotected and you have no way of really knowing if your MOV is good or not.
ddawg16 is online now   Reply With Quote
Old 01-19-2012, 08:16 AM   #5
Rewards Points: 826
Originally Posted by Trucon01 View Post
Hi All,
Is your power fed overhead or underground? If underground it may not be as useful as those systems tend to have fewer transients on them. Its pretty cheap insurance though so you really can't lose.
curiousB is offline   Reply With Quote
Condensor Unit Wiring issues with Square D QO Breaker Perry401 Electrical 19 06-06-2011 09:26 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
