#1 |
secondar outlets in a gfi circuit
i have an gfi out that seems to be working porperly i plug in and tha appliance works there are 2 more outlets wired to this main outlet and there is power to these outlets and when i plug in an appliance it main gfi trips checked all wires changed the gfi outlet and still same problems where to go from here? bob
#2 |
Licensed electrician
If the appliance is tripping the GFI it needs to be repaired or replaced.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
Try pluging in something else and see if it still trips.
100% sure you have the line and loads hooked up right? Line is incoming power, load is anything down line from the first outlet. Anything sharing a nutral? |
#4 | |
secondar outlets in a gfi circuitQuote:
#5 |
I think the keyboard is broken too.
#6 |
One loose connection is going to cause a GFI to trip.
| The Following User Says Thank You to joecaption For This Useful Post: | rgoodell (11-20-2012) |
#7 |
have not found a loose connection or a boken wire
#8 |
Electrical Contractor
Where are these receptacles located?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#9 |
Since it works OK on the GFI outlet, but not on the 2nd and on down the line, it sounds like the problem would be somewhere from the "load" connection on the GFI to the 2nd socket (the 1st socket down stream from the GFI).
In the workbox for the 2nd outlet, you could disconnect the wires leading to the 3rd outlet, but leave all the rest connected. If you still have the problem, you've isolated it to GFI --> Outlet-2. If the problem disappears, then it's downstream of outlet-2. |
| Display Modes | |
| Best tools and efficient method for identifying outlets on a circuit, please. | justplumducky | Electrical | 9 | 07-08-2012 10:27 AM |
| Dimming lights on one circuit, GFCI breaker tripped | boatman537 | Electrical | 4 | 06-05-2012 11:43 AM |
| 120-V outlets and 240-V outlet on same double-pole circuit? | Daneel | Electrical | 24 | 04-04-2012 12:22 AM |
| how many outlets do you recommend on 15A circuit? | Jeremy Hillary Boob, PhD | Electrical | 10 | 03-03-2012 12:16 PM |
| Open circuit has power, close the circuit no power??? | BeginnerHomeDIY | Electrical | 7 | 07-08-2009 03:40 PM |
