Second Line From GFCI Shut It All Down - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 11:54 AM   #1
Rewards Points: 664
Second line from GFCI shut it all down
I had an ungrounded outlet that feed another outlet that powers my water softener. Rather than make these outlets two prong I added a GFCI that powered the downstream water softener outlet. In addition to the water softener there is another unknown line fed by the GFCI.
So I have a GFCI with two lines going out from the “load” side with one going to an unknown location and the other to my water softener outlet. This system worked fine for a couple months, but then I noticed the water softener no longer worked. I reset the GFCI and the light blinked and immediately went out. I disconnected the unknown line and now it all works fine. I do not know where that other line went, but obviously it went to something that caused trouble for the GFCI. What would cause this to occur and why were things fine for two months?
Thank you in advance to all who help.
crescere is offline   Reply With Quote
Old 04-24-2013, 12:15 PM   #2
jproffer's Avatar
Rewards Points: 702
Could be an outdoor receptacle, could be a basement receptacle, or almost anywhere really. It's hard to give you a "why" if you don't know where/what we're even talking about.
BTW, how did you attach 2 sets of conductors to the load side of the GFI? All the ones I've ever seen have one set of screws for the load side. (I understand maybe you pigtailed them...I'm just curious)
jproffer is offline   Reply With Quote
Old 04-24-2013, 03:21 PM   #3
Rewards Points: 664
I will ultimately have to go under my crawl sapce and I am not looking forward to that. I am just wondering what type of thing could cause this to happen.
GFCIs do have two openings under the screw for wires. I have never seen one with just one. I got it at Home Depot.
Old 04-24-2013, 03:46 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
It could feed to an outside receptacle in a flower bed.
It could have been chewed by mice.
It could just be open wires that have finally contacted dirt, or non of the above and many other reasons.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Philly Master (04-24-2013)
gfci question bernie963 Electrical 6 02-08-2013 10:45 AM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 03:29 PM
GFCI grounding; and inside double gang box? Wildswalle Electrical 5 05-29-2011 02:25 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 06:14 PM
