Second Ground Rod??? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 10:45 AM   #1
Second ground rod???
I recently moved into a home where a subpanel was added and it is right next to the main panel. To my knowledge, it is not installed correctly.
They basically extended a 60a breaker withand the grounds and neutrals are hooked together in the sub.
It is my understanding that the grounds are to be separated from the neutrals and to be on a separate buss bar that is bonded to the panel.
My question is---Can I run a fourth wire(ground wire) to the main panel and connect to the existing main panel ground rod, or do I need to terminate this fourth wire to a new ground rod driven in the ground outside?
Giles is offline   Reply With Quote
Old 02-08-2010, 11:20 AM   #2
How old is the house ?
How old is the sub-panel ?
Yes, run the 4th wire & seperate the grounds & neutrals
The ground should terminate on one of the grounding/neutral bars in the main panel
Old 02-08-2010, 11:39 AM   #3
Home and wireing is app. 22 years old with sub being installed 2years ago.
So, do I have it correct that I can connect the ground wire from the subpanel to the main panel ground without having to add a second ground rod?
Old 02-08-2010, 11:41 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
If it is in conduit, then you can run the 4th wire. If it is fed with cable, then you cannot add a wire, you must replace the cable.
jbfan is online now   Reply With Quote
Old 02-08-2010, 11:51 AM   #5
It is fed with three single conducter #6 with boxes about 6" apart. No conduit. But I can easily add conduit.
Old 02-08-2010, 11:57 AM   #6
Is it a metal conduit ?
That could act as ground
Old 02-08-2010, 12:15 PM   #7
No there is no conduit. I have edited my last post. Sorry I didn't answer the question completly.
Old 02-08-2010, 12:19 PM   #8
jbfan's Avatar
Rewards Points: 138
Conduit needs to be added, and you can use a #10 green wire for the ground.
Old 02-08-2010, 12:25 PM   #9
Ouch...no conduit & it was added 2 years ago
Definitely not up to code !!
Old 02-08-2010, 12:37 PM   #10
Licensed electrician
Rewards Points: 1,018
Someone please tell me that there are not just 3 conductors hanging in the air between the 2 panels.
Old 02-08-2010, 02:01 PM   #11
jbfan's Avatar
Rewards Points: 138
Would you beleive us if we did?
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 11:14 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
Ground question. mystery guest Electrical 5 07-24-2008 01:47 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
