Sears Cordless Hedger - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 11:11 AM   #1
Sears cordless hedger
I have a Sears cordless hedger and I just bought 2 new batteries for it. It has been a while since I took the old batteries out so I don't remember how the batteries are wired. There are 2 batteries and 3 wires. 1 red wire, 1 black wire and a green jumper wire. Does anyone know how the wiring should be to connect the 2 batteries together. Any help would be greatly appreciated.
Dave 641 is offline   Reply With Quote
Old 03-05-2011, 11:36 AM   #2
BIGRED
Rewards Points: 252
If each battery is approximately 1/2 of the placarded operating voltage then it would be black from one battery to the minus or negative lead of the trimmer, red from that battery to black of the 2nd battery and red from the 2nd battery to the trigger switch. If on the other hand, both batteries are within a volt or two of the operating voltage, then both blacks are tied together with the negative of the trimmer and both reds are tied together and run to the trigger switch. The green wire may or may not be used. If you wish to keep it, connect it to the metal motor housing.
Grampa Bud is offline   Reply With Quote
Confused on the cordless drills scarrylarry Tools 6 07-15-2010 03:26 PM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 04:20 PM
Cordless Cellular Blinds kristan Interior Decorating 8 01-17-2010 09:33 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
